Vocore gpiod line-names
Posted: Fri Feb 03, 2023 2:57 pm
Hi, I'm trying to label the GPIO of the Vocore so I can use them with "gpio".
I added the following to the vocore device tree but I get a weird artifact when I do `gpioinfo`
output of gpioinfo command
What I think is happening is that the three gpio banks of the vocore are not defined in the m7628an.dts files so it thinks its only one bank.
Does anybody know how to define the three banks?
Thanks in advance!
&gpio {
gpio-line-names = /* 00 - 07 */ "", "", "", "", "", "", "", "",
/* 08 - 15 */ "", "", "", "TEST", "", "", "", "",
/* 16 - 23 */ "", "", "", "", "", "", "", "",
/* 24 - 31 */ "", "", "", "", "", "", "", "";
gpiochip0 - 32 lines:
line 0: unnamed unused input active-high
line 1: unnamed unused input active-high
line 2: unnamed unused input active-high
line 3: unnamed unused input active-high
line 4: unnamed unused input active-high
line 5: unnamed unused input active-high
line 6: unnamed unused input active-high
line 7: unnamed unused input active-high
line 8: unnamed unused input active-high
line 9: unnamed unused input active-high
line 10: unnamed unused input active-high
line 11: "TEST" unused input active-high
line 12: unnamed unused input active-high
line 13: unnamed unused input active-high
line 14: unnamed unused input active-high
line 15: unnamed unused input active-high
line 16: unnamed unused input active-high
line 17: unnamed unused input active-high
line 18: unnamed unused input active-high
line 19: unnamed unused input active-high
line 20: unnamed unused input active-high
line 21: unnamed unused input active-high
line 22: unnamed unused input active-high
line 23: unnamed unused input active-high
line 24: unnamed unused input active-high
line 25: unnamed unused input active-high
line 26: unnamed unused input active-high
line 27: unnamed unused input active-high
line 28: unnamed unused input active-high
line 29: unnamed unused input active-high
line 30: unnamed unused input active-high
line 31: unnamed unused input active-high
gpiochip1 - 32 lines:
line 12: unnamed "fuchsia:status" output active-high [used]
gpiochip2 - 32 lines:
Thanks in advance!
