Cumulative patch with mmc support
User avatar
scythe
Mon Jun 08, 2015 3:39 pm
Hi all,
I've created a cumulative patch with mmc support for OpenWRT from the following 3 components:
These are basically all the modifications needed to build an mmc compatible OpenWRT for the VoCore, instructions all from http://vonger.cn/?p=1637.
Tested on Chaos Calmer Bleeding Edge, r45926, kernel 3.18.14.
root@OpenWrt:/# [ 1927.630000] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1927.640000] mmc0: new SD card on SPI
[ 1927.650000] mmcblk0: mmc0:0000 SA02G 1.83 GiB
[ 1927.720000] mmcblk0: p1 p2 p3
root@OpenWrt:/# mount
/dev/mmcblk0p2 on /mnt type ext3 (rw,relatime,data=ordered)
Download the patch from http://storage.googleapis.com/kasza/vocore_mmc.patch.
Also, here is the compiled firmware http://storage.googleapis.com/kasza/vocore_mmc_16mb_r45926.bin (3 407 876 bytes).
If you want luci, fdisk or FAT support, you'll have to change the options in OpenWRT Buildroot and recompile, the above firmware is using the default options without these tools.
Regards,
Karoly
Users browsing this forum: No registered users and 384 guests
