I2C Basic Setup
danie
I2C Basic Setup
Thu Dec 03, 2015 4:51 am
I would like to use I2C on a LPS331AP sensor IC. I am struggling with I2C on the Vocore.
Can somebody perhaps post a simple recipe to setup I2C on the Vocore ? I am a beginner with OpenWrt and Linux.
My connections are: (not sure if this is correct)
BOARD VCC -> VoCore 3.3V
BOARD GND -> VoCore GND
BOARD SCL -> VoCore G#02/I2C_SCLK
BOARD SDA -> VoCore G#01/I2C_SD
I have a white Vocore v1.0 and Linux command uname -a reports:
Linux OpenWrt 3.10.49 #4 Tue Sep 15 22:04:56 EDT 2015 mips GNU/Linux
Re: I2C Basic Setup
Thu Dec 03, 2015 1:57 pm
I think you forget the pull up 4.7Kohm resistor for I2C CLK and I2C DAT. :mrgreen:
danie
Re: I2C Basic Setup
Sun Dec 06, 2015 4:20 pm
hey i got my i2c working ! here is the recipe:
1. load latest firmware ie 3.18.20 ; use web interface , it works well
2. enable internet for AP + STA ; use Vonger's recipe
3. opkg update
4. change passwd for good measures :-)
5. copy i2c tools over from openwrt repository with pc (to pc hard disk)
6. Use WinSCP to copy these files to /root on vocore
7. opkg install <filenames> {to install the i2c packages)
8. check now i2c devices: ls /dev/i*
9.check the LPS331AP device: i2cdetect -r 0
10. load data from sensor: i2cdump -y 0 0x5d
there is it !! thanks to all those who helped me :-)
ps the Pololu LPS331AP has pull-ups and everything. that was not the issue.
Users browsing this forum: No registered users and 68 guests
