I2S lines on VoCore
eragefe
I2S lines on VoCore
Tue Jun 02, 2015 12:11 am
Does anybody knows how to activate the I2S lines on VoCore?
Not much information about that. I guess some modules have to be compiled/loaded like on RPi.
I would appreciate any kind of help about that.
Thanks BRG
Re: I2S lines on VoCore
Tue Jun 02, 2015 1:09 am
First, you need to setup some register to enable I2S(check RT5350 datasheet, vonger.cn/upload/RT5350F.pdf)
SYSCTRL: 0x0060, enable I2S pinmux, make it to I2S + GPIO
Then, update 0x0a00, which is I2S control, setup register to I2S master mode, enable PLL(which is for BCLK and LRCLK), then write to TX register, every thing will be done.
I am writing something on my blog about audio and I2S, should be done in this month.
eragefe
Tue Jun 02, 2015 11:52 am
Ok Thanks
Cron
Tue Jun 16, 2015 3:20 pm
Vonger wrote:First, you need to setup some register to enable I2S(check RT5350 datasheet, vonger.cn/upload/RT5350F.pdf)
Hi Vonger!
Thank you for the I2S posts on your blog. I've successfully ported an I2S driver from Ralink SDK to OpenWRT and I have a sound, but... The sound is distorted and slowed. Maybe because I don't use a GDMA (I just can't make it work) or whatever the reason. I really hope you will find (already?) a solution! Can't wait for the part 3 of "I2S Sound Card WM8960G". :roll:
Sat Jun 20, 2015 2:55 am
Yes, I will :) I am writing it, and trying to make it easy to understand. :)
Hi Vonger!
Cron
Tue Dec 08, 2015 5:04 pm
Hi Vonger!
I saw your last post about new Dock2 Firmware and OpenWRT built-in I2S/DMA support. It's great and looks very clean... but I found it a bit complicated in some cases. It should perfectly do the job, but only if the codec chip is supported by ALSA, like WM8960, otherwise you're screwed... That's why I loved the raw I2S driver from Ralink's SDK, it works in any case and with all IC's, for example with my TFA9879.
Can you publish your raw I2S/DMA drivers, even they aren't finished please? :roll:
Thu Dec 10, 2015 1:10 am
eragefe wrote:Does anybody knows how to activate the I2S lines on VoCore?
Thanks BRG
Ye, will do it soon. but better to modify from current alsa i2s driver, it is not just i2s but also a lot of software based on ALSA :)
Cron
Mon Dec 14, 2015 12:01 pm
Yeah sure, ALSA is way better, but when you need to make some "beeps" and you don't have enough skills to make your hardware work with it, a simple access to I2S lines is better than nothing ;)
Tue Dec 15, 2015 8:19 am
Understand :)
We do not have much hands here(hope more hands later), will post a blog about it after vocore2 antenna.
nbmaiti
Tue Jan 05, 2016 7:20 pm
Still I'm unable to get to load the drivers.
Using barrier braker git tip
commit e79c72f42c5e93eaa3247a26352c1448edaa1008
Author: jow <jow@3c298f89-4303-0410-b956-a3cf2f4a3e73>
Date:   Mon Dec 7 16:30:59 2015 +0000
    BB: scripts/feeds: add support for optionally using a full clone of git repositories
With changes as suggested in blog - in link https://drive.google.com/open?id=0B5HCBWNiwHrFa0hzMnVWUTRQYW8
Can you please share your working diff for audio dock?
Next
Users browsing this forum: Google [Bot] and 16 guests
