In some threads related to u-boot it was mentioned flashing the SPI chip with an external programmer. Can this be done in circuit? Won't applying power to Vcc enable the processor? Any suggestions for how to flash using an external programmer?
Thank you
SPI flash programming
- dl9sec
Re: SPI flash programming
I would say yes. I am currently experimenting with that on another RT5350 board.
E.g. this programmer should work: https://www.flashrom.org/Teensy_3.1_SPI ... WH_Flasher
together with a suitable clip (e.g. http://www.ebay.de/itm/Test-Clip-Progra ... SwNgxWEroL).
I am running the programmer on a breadboard.
The VoCore board should be powered, but the CPU held in reset applying a low to POR_N. At the programmer only the SPI pins and GND should be connected.
I will try this the next few days and can give you feedback...
Regards, Thorsten
Edit:
Confirm. It really works as described above. Apply the following signals from the programmer to the flash:
1: SPI CS, 2: SPI MISO, 3: +3V3, 4: GND, 5: SPI MOSI, 6: SPI CLK, 7: +3V3, 8: +3V3. The +3V3 are provided by the booard, not by the programmer and shorted on the programmers breadboard.
I read/wrote the flash on my board (not a VoCore!) with flashrom:
flashrom -p serprog:dev=/dev/ttyACM0:1500000 -c MX25L3206E/MX25L3208E ...
Works like a charm!
Regards, Thorsten
Edit:
Works like a charm!
Here's how I did it, make sure you back up the factory partition first it is the only thing unique to each board that can't be duplicated by mortals. More details here on the software side.
Pulling PORST low keeps the 5350 from interfering in the process.Vonger's method #2 is intriguing but I haven't tried it.
Users browsing this forum: Baidu [Spider] and 26 guests
