LEDs are off after boot
madxray
Mon Jan 04, 2016 11:12 pm
after flashing my first self-compiled OpenWRT image for the VoCore the green status LED is not lit after booting. First I feared that I bricked my VoCore but it boots and establishes the WiFi client connection successfully.
I tried to change the LED brightness but without any effect:
echo 255 > /sys/devices/gpio-leds/leds/vocore\:green\:status/brightness
Now I do not know if something went wrong with the image (missing setting?) or if it is related to the removing of the dock and the RX and TX pins.
The fact that it is still working is most important but some visual indication would be good.
My steps:
1. checked out chaos calmer git
2. loaded and installed feeds
3. applied patch
4. make menuconfig and select libpthread
5. flashed
After first boot and no LED status indication I removed the RX and TX pins from the dock to connect the TTL2USB and figured out that it is still alive.During boot the LEDs show existence but are turned off when it is running.
Thank you
madxray
Re: LEDs are off after boot
Wed Jan 06, 2016 12:19 pm
Ok, it seems I found the missing information in vonger's blog: http://vonger.cn/?p=1934
Should I replace the existing VOCORE.dts or merge it with the changes? The blog just mentions "modify" what isn't very precisely ;)
It would be great if somebody can provide a Dockv2 patch (Chaos Calmer stable), not only the ready made firmware binary as most of us will need to modify the image. As soon as I find time I will share mine here.
Thank you
Sun Jan 17, 2016 8:35 am
madxray wrote:Ok, it seems I found the missing information in vonger's blog: http://vonger.cn/?p=1934
Thank you
Anyway make it works will be fine. Haha, thank you for the information about the word, I will update it. (I think in Chinglish "modify" is precisely :D)
We did not go to 15.05 yet, still in 14.07, you can get the firmware at http://vonger.cn/upload/firmware/
The only different is that we change the GPIO pins for the LEDS, enable pins for I2S and I2C(used to control WM8960), rest are same. :)
Users browsing this forum: No registered users and 131 guests
