Simple GPIO
- Kampi
- Peter H
Re: Simple GPIO
Was there a question? You have already been shown working code with an explanation of how it works.
- Kampi
Re: Simple GPIO
Sorry for confusion.
The Code doesn't work
I try to set a GPIO as an Outout, but if I run this Programm and read out the "direction" file of that GPIO he is already marked as an input.
This is my GPIO Lib (use a fix GPIO in the "Set_Dir" Function:
#include <sys/mman.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <unistd.h>
#include <fcntl.h>
#include <stdio.h>
#define BLOCK_SIZE 4096
#define Bus_Base 0x10000000
struct RT5350_Peripherie {
unsigned long Adresse;
int Memory;
void *Map;
volatile unsigned int *Addr;
struct RT5350_Peripherie Bus = {Bus_Base};
int Wert = 0;
int RAM_Map(struct RT5350_Peripherie *Peripherie)
Peripherie->Memory = open("/dev/mem", O_RDWR);
if(Peripherie->Memory < 0)
printf("Kein Zugriff auf /dev/mem!\n\r");
return -1;
Peripherie->Map = mmap(
NULL,
BLOCK_SIZE,
PROT_READ | PROT_WRITE,
MAP_SHARED,
Peripherie->Memory,
Peripherie->Adresse
if(Peripherie->Map < 0)
printf("Peripherie mappen fehlgeschlagen!\n\r");
return -1;
Peripherie->Addr = (volatile unsigned int *)Peripherie->Map;
return 0;
int GPIO_Init(void)
if(RAM_Map(&Bus) == -1)
printf("GPIO Mappen fehlgeschlagen!\n\r");
return -1;
return 0;
int Set_Dir(int IO, char *Dir)
int Offset = 0;
int Shift = 0;
/*if(IO < 22)
Offset = (0x624>>2);
Shift = IO;
else if((IO > 21) & (IO < 29))
Offset = (0x674>>2);
Shift = IO - 22;
else
printf("Ungueltiger Wert fuer IO!\n\r");
return -1;
if(Dir == "I")
*(Bus.Addr + Offset) |= (1 << Shift);
else if(Dir == "O")
*(Bus.Addr + Offset) &= ~(1 << Shift);
else
printf("Ungueltiger Wert fuer Dir!\n\r");
return -1;
Wert = *(Bus.Addr + (0x67c >> 2));
printf("Offset: %i\n\r", Wert);
printf("IO: %i\n\r", (1 << Shift));
return 0;
- Greenwire-Elektronik
Re: Simple GPIO
i just tried what you have done - set the direction in 0x624h to 1 for the corresponding pin and then toggled the pin (0x634h) - value changes as does the voltage do - it is just a problem with the OS which will still show IN as direction - i do not think that i will be updated because this would mean that the system polls the status of all GPIOs.
You should validate your code with the voltage meter, not with the direction file
Rgds,
Jonas
Rgds,
Jonas
- Kampi
Re: Simple GPIO
Great! Thanks for your response!
I will try it later with my oscilloscope
- Kampi
Re: Simple GPIO
Hey,
I try the same with this Code:
This should toggle Pin 2, but nothing happens. I check it with my oscilloscope.
*(Bus.Addr + (0x624 >> 2)) = 1 << 2;
*(Bus.Addr + (0x634 >> 2)) = 1 << 2;
Re: Simple GPIO
Kampi wrote:Hey,
No wonder - if you look up the directory /sys/class/gpio you find all gpios which are exported - means available in user space. gpio 2 is not available, i think this might be the reason for your problem. You can try it with e.g. gpio14.
On a second thought (without checking) it could also be a problem with the multiplexed function on that pin which might interfere here.
Rgds
Jonas
Re: Simple GPIO
First make sure GPIO 26 is able to be used as GPIO. It is not be taken be other protocol.
Then make sure export the GPIO first(if you directly write to register, that is not necessary)
If the two steps are all right, it should be OK to use.
- franki
Re: Simple GPIO
I have vocore mounted in a self-made board... to verify the GPIO out from GPIO22 to GPIO26, a LED with a 330 ohms resistor in every out pin.... and the code works for me, but a little change....
The registers for de GPIO22 to GPIO26 are offset 0x670 to 0x684....
and this is the result for toggle is OK!!!
*(gpio + (0x674 >> 2)) = 31;
*(gpio + (0x684 >> 2)) = 31;
- Kampi
Re: Simple GPIO
Thanks it works now, but I think I found a misstake in the Datasheet (see attachment).
I think they swap the Description of Set and Clear....
- Error.png (38.79 KiB) Viewed 386032 times
Users browsing this forum: No registered users and 63 guests
