ssh close connection after insert password
vbextreme
Fri May 26, 2017 8:05 am
I access on vocore2 over luci without problems but if I try to connect over ssh the connection is closed afeter insert a password. Why?
Re: ssh close connection after insert password
Fri May 26, 2017 2:20 pm
weird issue, try mtk openwrt firmware, I guess it might be MT76 wifi driver issue.
link is here: http://vonger.cn/misc/vocore2/vocore2.mtk.bin
vbextreme
Sat May 27, 2017 7:32 am
The board does not start anymore, this is the second time I turn it on and I have not made any changes yet.
Is the firmware good for the lite version?
Sat May 27, 2017 9:40 am
You will need a USB2TTL to recover the firmware, please check vocore.io/v2.html
vbextreme
Sat May 27, 2017 10:09 am
ok, successfull
For those who have similar problems.
download vocore2 lite
connect serial usb
install ckermit
execute kermit
> set line /dev/ttyUSB0
> set speed 115200
> set handshake none
> set flow-control none
> set carrier-watch off
> robust
> connect
Please choose the operation:
> 0
0: System Load Linux then write to Flash via Serial.
## Ready for binary (kermit) download to 0x80100000 at 115200 bps...
press key Ctrl+\ c
> send /home/<username>/Downloads/<firmware>.bin
> q
thanks for support
[edit]
add set carrier-watch off
[/edit]
vbextreme
Sun May 28, 2017 7:55 am
Once again broken.
While I was exploring the filesystem i started getting format execute error.
Try to close ssh and reconnect with same problem, connection close after insert password.
Power off and power on, now not view vocore2 wifi.
crestfallen :(
vbextreme
Sun May 28, 2017 8:30 pm
I have found two issues
First::
usb 2-1 It continues to make mistakes
fix temporary
# echo 'rmmod ohci_platform' >> /etc/rc.local
Second::
Same time can't connect over wifi
this is original rc.local
uci commit
/etc/init.d/network restart
sleep 10
uci commit
It does not seem to make much sense
edit in
uci commit
rmmod ohci_platform
save and reboot, now wifi work.
You should also delete those rows and create a specific script to perform the task
Here you can find a good starting point
for example (not tested)
/root/try-sta.sh
uci commit
TIMEOUT=10
SLEEP=1
sta_err=0
while [ $(iwinfo | grep -c "ESSID: unknown") -ge 1 ]; do
   let sta_err=$sta_err+1
   if [ $((sta_err * SLEEP)) -ge $TIMEOUT ]; then
       uci commit
       break
   fi
   sleep $SLEEP
done
and in rc.local add
/root/try-sta.sh
It would be useful to blink the LED during this phase
vbextreme
Tue May 30, 2017 1:50 pm
Vocore2-lite is completely broken.
I try to download source code and try to build with this tutorial, but return error
gdate.c: In function 'g_date_strftime':
gdate.c:2497:7: error: format not a string literal, format string not checked [-Werror=format-nonliteral]
       tmplen = strftime (tmpbuf, tmpbufsize, locale_format, &tm);
Download LEDE, build and upload firmware, but after few minutes get strange and randomly charater from serial. Network over ap is very very slow and I can't enable AP+STA
In this situation I don't understand if is broken hardware or software.
Users browsing this forum: Google [Bot] and 141 guests
