New Mediatek WiFi Drivers for Vocore 2 Lite? LEDE?
rkk
Sat Jun 17, 2017 11:24 pm
Hi, I just saw this post: http://vonger.cn/?p=14252
Right now I'm on the latest firmware version for my Vocore 2 Lite and the speed tests I've done are slow as the LEDE drivers. Will there be any updates to the driver to use the Mediatek ones any soon? Is there any way to incorporate it into the current firmware?
And what about the LEDE firmware? How can I install the firmware from here http://vonger.cn/?p=14237 ?
Is it safe to use on the Vocore 2 Lite? Does it has the new WiFi driver?
Greetings and thanks!
nbash
Re: New Mediatek WiFi Drivers for Vocore 2 Lite? LEDE?
Sun Jun 18, 2017 2:38 pm
i join to the question.
if this is a license problem... how can i add mtwifi to source of lede?
rkk
Tue Jun 20, 2017 8:15 am
Any news of @Vonger? It would be nice if he could give some input or comment about this..
Tue Jun 20, 2017 4:09 pm
Actually you can get mediatek wifi driver source code everywhere :)
If you want use it, must compile it and use it as blob.
nbash
Tue Jun 20, 2017 6:36 pm
I assume, it is possible to operate similarly: https://github.com/wuqiong/rt2860v2-for-openwrt-mt7620
But I didn't check yet
UPD
Having used instruction on the link.
I am put contents of mtwifi archive to the directory build_dir/target-mipsel_24kc_musl/linux-ramips_mt7628/linux-4.4.61/drivers/net/wireless/mt_wifi
I have added strings about mtwifi driver to the files Makefile and Kconfig of directory build_dir/target-mipsel_24kc_musl/linux-ramips_mt7628/linux-4.4.61/drivers/net/wireless/
Makefile: obj-$(CONFIG_MT_WIFI)   += mt_wifi/build/
Kconfig: source "drivers/net/wireless/mt_wifi/build/Kconfig"
(maybe it is necessary to move build contents to the root of mt_wifi?)
Now, I execute
make kernel_menuconfig
and have seen
Device Drivers  ---> [*] Network device support  ---> [*]   Wireless LAN  --->
<*>   Ralink RT2860 802.11n AP support
[*]     WDS
[*]     MBSSID
[*]     AP-Client Support
[*]       MAC Repeater Support
[*]     LLTD (Link Layer Topology Discovery Protocol)
[*]     AIRPLAY Support
(exactly Ralink RT2860 802.11n AP support !!!)
After then, I have checked everything, and exit with save.
make V=99
executed, and doesn't yield result, driver has been ignored at compile.
rkk
Wed Jun 21, 2017 7:02 pm
Can you @Vonger provide us the required WiFi blobs that you used in your comparison blog? (http://vonger.cn/?p=14252). Or is it required to compile it every time?
nbash
Thu Jun 22, 2017 8:52 am
Wow, what i have found:
root@OpenWrt:/# lsmod | grep mt_wifi
mt_wifi              1325309  1
http://vonger.cn/misc/vocore2/20170527V.bin
rkk
Mon Jun 26, 2017 5:07 pm
Nice!!! Were you @nbash able to make the driver work in LEDE? The LEDE image that Vonger posted on his Blog is still using the non-official driver.
BTW, the the firmware for Vocore 2 Lite is 20170211 while all the other (Non-Lite) are 20170527. Is there any reason why the Lite versions are outdated? Is @vonger still updating the Firmwares or not anymore?
nbash
Fri Jun 30, 2017 12:01 pm
No, I didn't. I did not like the mt_wifi driver, it does not support ap+sta and MESH/ADHOC mode.
I not up to the end understand that 'LITE' means and where people buy it. I bought the standard version according to the link: http://vocore.io/v2.html it's 'LITE' or what is this?
rkk
Sat Jul 01, 2017 10:19 am
I got mine on Indiegogo.
Here you see a comparison: http://vocore.io/img/compare.png
Basically the Lite version has 64MB RAM and 8MB of storage. Everything else seems to be pretty much the same.
I tried flashing the 20170527V.bin firmware (The one with MT Driver), which resulted in a bricked Vocore 2. Altough I managed to flash the Ultimate firmware, but the RAM amount is double (Hardcoded?).
Do you know where I can find info on how to make the MT_Driver work in LEDE?
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
