VoCore2 Lite connection lost, factory reset might be needed
limberjack
Re: VoCore2 Lite connection lost, factory reset might be nee
Tue Aug 08, 2017 8:57 pm
Hi there,
sorry for the late but didnt had time for play with that small dude...
OK now i fixed the PSU and now i have that code
[   36.810000] device ra0 left promiscuous mode
[   36.810000] br-lan: port 2(ra0) entered disabled state
[   37.020000] device eth0 left promiscuous mode
[   38.950000] device eth0.1 entered promiscuous mode
[   38.950000] device eth0 entered promiscuous mode
[   38.960000] br-lan: port 1(eth0.1) entered forwarding state
[   38.970000] br-lan: port 1(eth0.1) entered forwarding state
[   40.280000] device ra0 entered promiscuous mode
[   40.280000] br-lan: port 2(ra0) entered forwarding state
[   40.290000] br-lan: port 2(ra0) entered forwarding state
[   40.970000] br-lan: port 1(eth0.1) entered forwarding state
[   42.290000] br-lan: port 2(ra0) entered forwarding state
[   71.920000] random: nonblocking pool is initialized
after that code i got nothing and i just hit the return and voila i got
BusyBox v1.23.2 (2017-01-25 15:51:22 CST) built-in shell (ash)
  * 1 1/2 oz Gin            Shake with a glassful
  * 1/4 oz Triple Sec       of broken ice and pour
  * 3/4 oz Lime Juice       unstrained into a goblet.
  * 1 1/2 oz Orange Juice
  * 1 tsp. Grenadine Syrup
root@OpenWrt:/#
But still my wireless doesnt work, i am going to check the settings you told me in the earlier post, so update on the issue will be posted latter!
Tue Aug 08, 2017 9:44 pm
Good, keep learning and you'll be a guru in no time. There are a lot of posts in this thread so to be sure you find the one I recommend it is this one because I put it together with a fresh load of the image from vocore.
If you run into other problems post them. Please start a new thread for a new problem though, some people (especially me) can be a real jackass about one issue per thread.
limberjack
Tue Aug 08, 2017 10:23 pm
So i have that in my
/etc/config/wireless
fi-device 'radio0'
        option type 'ralink'
        option variant 'mt7628'
        option country 'CN'
        option hwmode '11g'
        option htmode 'HT40'
        option channel 'auto'
        option disabled '0'
config wifi-iface 'ap'
        option device 'radio0'
        option mode 'ap'
        option network 'lan'
        option ifname 'ra0'
        option ssid 'VoCore2'
        option encryption 'none'
config wifi-iface 'sta'
        option mode 'sta'
        option network 'wwan'
        option ifname 'apcli0'
        option ssid 'Enisey'
        option key 'parola123'
        option encryption 'psk2'
        option disabled '0'
still i cant bring up the wireless
here what i have after network reset
[ 5110.110000] br-lan: port 2(ra0) entered disabled state
[ 5110.120000] br-lan: port 1(eth0.1) entered disabled state
[ 5110.130000] device eth0.1 left promiscuous mode
[ 5110.130000] br-lan: port 1(eth0.1) entered disabled state
[ 5110.140000] IPv6: ADDRCONF(NETDEV_UP): eth0.1: link is not ready
[ 5110.170000] device ra0 left promiscuous mode
[ 5110.170000] br-lan: port 2(ra0) entered disabled state
[ 5110.410000] device eth0 left promiscuous mode
root@OpenWrt:/# [ 5112.310000] device eth0.1 entered promiscuous mode
[ 5112.320000] device eth0 entered promiscuous mode
[ 5112.320000] br-lan: port 1(eth0.1) entered forwarding state
[ 5112.330000] br-lan: port 1(eth0.1) entered forwarding state
[ 5113.070000] device ra0 entered promiscuous mode
[ 5113.080000] br-lan: port 2(ra0) entered forwarding state
[ 5114.330000] br-lan: port 1(eth0.1) entered forwarding state
[ 5115.080000] br-lan: port 2(ra0) entered forwarding state
Any idea for that ?
Wed Aug 09, 2017 5:57 pm
What does logread say?
Only end of the output is relevant.
limberjack
Thu Aug 10, 2017 7:23 pm
Hello "noblepepper"
I am pretty sure i posted that i have my wifi alive, i don't know why the threat is not updated.
However, i have my wifi back. I messed
so i just deleted the file and created new one with default settings and the settings needed for connection to my home network.
Now everything works OK - for now, i have connection to my VoCore2 Lite over Web, SSH, and USB-TTL
Thanks to "noblepepper" the threat is finished and can be locked from the moderators.
Fri Aug 11, 2017 12:12 pm
saveenv is not working because linux do not load that at all.
you should set that in VOCORE2.dts when you compile it.
if your wifi is dead, hexdump -C /dev/mtd2, check if the data is all 0xff, if so, the factory is dead.
if not, try firstboot -y, recover the setting.
limberjack
Fri Aug 11, 2017 6:53 pm
Thanks one more time :!: :!: really good work!
Previous
