PoE
CrossbowMarty
PoE
Fri Oct 23, 2015 3:37 am
HI,
Am new to the forum but have had a bit of a surf around. Was wondering if it would be possible to power a VoCore with PoE?
Has anyone attempted this?
Regards
Marty
Re: PoE
Fri Oct 23, 2015 11:33 am
Current dock do not allow PoE :)
CrossbowMarty
Re: PoE
Fri Oct 30, 2015 3:23 am
This would seem to me to be a great idea. The VoCore is cheap enough to use on remote sensors and supplying power over the cat5 / cat6 cable lets me power all of these from a single PoE switch. So convenient!
What do you think Forum dwellers? Is there anyone else out there that thinks this is a good idea?
Would it need a new RJ45 socket?
Circuitry for the power should be pretty straightforward.
Re: PoE
Fri Oct 30, 2015 4:53 pm
Ye, it is a good idea :)
My target is to make it as small as possible, but PoE voltage is so high, have to use big components, I can not make it as small as current dock, so I give it up.
I courage you do it, make one for fun :D
ArkEngr
Re: PoE
Fri Oct 30, 2015 7:31 pm
CC1R5-4803SF-E is as close as I could find. It is 16x16mm and has an input voltage of 36 - 76 volts and puts out 3.3 volts at 400ma. DigiKey sells it.
CrossbowMarty
Re: PoE
Mon Nov 13, 2017 9:24 am
Am thinking that simply injecting a lower voltage and doing without all the hassle of PoE might make more sense.
Re: PoE
Wed Nov 15, 2017 12:23 pm
CrossbowMarty wrote:Am thinking that simply injecting a lower voltage and doing without all the hassle of PoE might make more sense.
VoCore2 has PoE dock.
Users browsing this forum: Google [Bot] and 7 guests
