I would like to configure an SD card to expand the root file system so I can install additional packages.
I notice a new directory mmcblk0 appears in dev when I insert the card.
When I navigate to the "mount points" section on the Vocore's web control panel, I see the volume appears in the SWAP list.
How can I configure the card to expand the root file system? The goal is to allow additional space to install packages and work on projects within the root environment.
Thank you.
Configuring SD card to expand the root file system
- www139
- KingBeetle
Re: Configuring SD card to expand the root file system
I followed this https://samhobbs.co.uk/2013/11/more-space-for-packages-with-extroot-on-your-openwrt-router and moved my root filesystem to a USB thumbdrive with great success.
I don't see any reason it wouldn't work just as easily for an SD card. Just a matter of replacing /dev/sdX with the path to your SD card.
Be aware however I don't have an SD card slot on my VoCore, nor have I tried it with an SD card, so try it at your own risk.
- www139
Unfortunately, since I originally started this thread, I corresponded with Vonger and it was suggested I update the firmware on my Vocore. Upon updating, I have 10x more available space but now the sd card is no longer recognized.
Users browsing this forum: Google [Bot] and 43 guests
