Damaged H.264 stream
jab
Thu Feb 14, 2019 2:37 pm
After some time of using VoCam camera, a green segments started to appear in the H.264 video stream. See attached image. In higher resolutions, this error is more visible. This happens only in H.264 stream, MJPG stream is not affected at all.
Re: Damaged H.264 stream
Fri Feb 15, 2019 11:02 am
if power off it wait one minute then connect, is it same result?
jab
Fri Feb 15, 2019 12:08 pm
Yes, this "Matrix" noise appears every time since the problem started occur.
Sun Feb 17, 2019 1:02 am
I see, I will contact the chip FAE, maybe it is firmware issue.
Sun Apr 05, 2020 1:08 pm
It should be some key frame loss package. If mjpeg works, that means hardware should be normal, please try the source code in SDK to record some h264 video from the camera, check if the problem is still there.
Return to VoCam264 & Screen
