WiFi FCC certification
glbaldini
Thu Feb 21, 2019 9:33 am
The tests for WiFi FCC certification require that the WiFi module be placed in continuous transmission at a fixed frequency.
Is there any way to get this with the Vocore2?
Re: WiFi FCC certification
Thu Feb 21, 2019 2:49 pm
Yes, this require your wifi driver support it.
We already have FCC.
glbaldini
Sat Feb 23, 2019 8:14 am
The wifi driver is the standard one, included in the image of Vocore2 that we have downoloaded.
Can you please tell me which is the command od the procedure to set the WiFi in fixed frequency transmission?
Thank you
Mon Feb 25, 2019 10:43 am
VoCore2 already has FCCID, please directly use it, you do not need to setting it.
glbaldini
Mon Feb 25, 2019 2:04 pm
Thank you, I'll try using the existing FCC certificate.
I see that there's also a CE certificate, but it is related to the old R&TTE directive.
Is there a certificate according to the new RED directive?
Tue Feb 26, 2019 9:00 am
CE RED need to do with production. so we do not have that.
And in the wifi driver source code there is a help documentation.
dieguz
Mon Mar 04, 2019 2:42 pm
Vonger wrote:CE RED need to do with production. so we do not have that.
Hi, I need these indications too, in which path of openwrt sources I find the wifi driver source with the indications?
Thanks!
Tue Mar 05, 2019 11:53 pm
it is in mt7628 source code, src/embedded/doc, check iwpriv_usage.txt and ate_iwpriv_usage.txt
If it is not easy to understand, please email to our support@vocore.io, we can send you the test process of the FCC cert, might help you do you CE.
dieguz
Wed Mar 13, 2019 9:58 am
Vonger wrote:it is in mt7628 source code, src/embedded/doc, check iwpriv_usage.txt and ate_iwpriv_usage.txt
Hi, I tried to send you a reply email to support@vocore.io but the mail is not delivered, the error is : 550 Domain frequency limited.
How can I contact You ?
Thanks
Thu Mar 14, 2019 4:48 pm
that is weird...please try to email to tasie@vocore.io
Next
Users browsing this forum: Google [Bot] and 84 guests
