5.9.7 -I../../include/QtNetwork/5.9.7/QtNetwork -I../../include/QtCore/5.9.7 -I../../include/QtCore/5.9.7/QtCore -I../../include/QtCore -I.moc -I../../mkspecs/linux-openwrt-g++ -o .obj/qssldiffiehellmanparameters_openssl.o ssl/qssldiffiehellmanparameters_openssl.cpp
ssl/qssldiffiehellmanparameters_openssl.cpp: In function 'bool isSafeDH(DH*)':
ssl/qssldiffiehellmanparameters_openssl.cpp:66:25: error: invalid use of incomplete type 'DH {aka struct dh_st}'
if (q_BN_num_bits(dh->p) < 1024) {
In file included from /home/pve/openwrt/staging_dir/target-mipsel_24kc_musl/usr/include/openssl/crypto.h:131:0,
from /home/pve/openwrt/staging_dir/target-mipsel_24kc_musl/usr/include/openssl/bio.h:69,
from /home/pve/openwrt/staging_dir/target-mipsel_24kc_musl/usr/include/openssl/ssl.h:152,
from ../../include/QtNetwork/5.9.7/QtNetwork/private/../../../../../src/network/ssl/qsslcontext_openssl_p.h:60,
from ../../include/QtNetwork/5.9.7/QtNetwork/private/qsslcontext_openssl_p.h:1,
from ssl/qsslsocket_p.h:62,
from ssl/qssldiffiehellmanparameters_p.h:60,
from ssl/qssldiffiehellmanparameters_openssl.cpp:41:
/home/pve/openwrt/staging_dir/target-mipsel_24kc_musl/usr/include/openssl/ossl_typ.h:140:16: note: forward declaration of 'DH {aka struct dh_st}'
typedef struct dh_st DH;
and more, more …
18.06.2 QT5 build fails
- Valeron70
As in vonger's tutorial "VoCore2: Develop on Qt Creator" I select QT5 as 'M' and run make, but get this errors:
Re: 18.06.2 QT5 build fails
I do not find any of such issue, from the log maybe missing openssl library? (should be libcrypt issue)
I use linux and mac both compiled no problem and works well. what system you are using?
Or you can exactly follow my instruction at github.com/vonger/vocore2, do not add or remove any package(use my .config), then compile. check if there still any issue. If everything works you can do some modify.
Also make sure you install everything necessary to compile it, check vocore.io/v2.html, compile part, some tools need to be installed by apt-get before you compile it.
- Valeron70
I build system as "github.com/vonger/vocore2", but I do "update -a"
After select libopenssl in .config :
.obj/qsslsocket_openssl.o: In function `QSslSocketBackendPrivate::continueHandshake()':
qsslsocket_openssl.cpp:(.text+0xe40): undefined reference to `QSslContext::npnContext() const'
qsslsocket_openssl.cpp:(.text+0xe48): undefined reference to `QSslContext::npnContext() const'
qsslsocket_openssl.cpp:(.text+0xe5c): undefined reference to `QSslContext::npnContext() const'
qsslsocket_openssl.cpp:(.text+0xe64): undefined reference to `QSslContext::npnContext() const'
Makefile:581: recipe for target '../../lib/libQt5Network.so.5.9.7' failed
make[7]: *** [../../lib/libQt5Network.so.5.9.7] Error 1
make[7]: Leaving directory '/home/pve/openwrt/build_dir/target-mipsel_24kc_musl/qt-everywhere-opensource-src-5.9.7/qtbase/src/network'
Makefile:269: recipe for target 'sub-network-make_first' failed
make[6]: *** [sub-network-make_first] Error 2
make[6]: Leaving directory '/home/pve/openwrt/build_dir/target-mipsel_24kc_musl/qt-everywhere-opensource-src-5.9.7/qtbase/src'
Makefile:48: recipe for target 'sub-src-make_first' failed
make[5]: *** [sub-src-make_first] Error 2
make[5]: Leaving directory '/home/pve/openwrt/build_dir/target-mipsel_24kc_musl/qt-everywhere-opensource-src-5.9.7/qtbase'
Makefile:76: recipe for target 'module-qtbase-make_first' failed
make[4]: *** [module-qtbase-make_first] Error 2
make[4]: Leaving directory '/home/pve/openwrt/build_dir/target-mipsel_24kc_musl/qt-everywhere-opensource-src-5.9.7'
Makefile:241: recipe for target '/home/pve/openwrt/build_dir/target-mipsel_24kc_musl/qt-everywhere-opensource-src-5.9.7/.built' failed
make[3]: *** [/home/pve/openwrt/build_dir/target-mipsel_24kc_musl/qt-everywhere-opensource-src-5.9.7/.built] Error 2
make[3]: Leaving directory '/home/pve/openwrt/package/vocore2/qt5'
time: package/vocore2/qt5/compile#37.52#4.14#45.88
package/Makefile:107: recipe for target 'package/vocore2/qt5/compile' failed
make[2]: *** [package/vocore2/qt5/compile] Error 2
make[2]: Leaving directory '/home/pve/openwrt'
package/Makefile:103: recipe for target '/home/pve/openwrt/staging_dir/target-mipsel_24kc_musl/stamp/.package_compile' failed
make[1]: *** [/home/pve/openwrt/staging_dir/target-mipsel_24kc_musl/stamp/.package_compile] Error 2
make[1]: Leaving directory '/home/pve/openwrt'
/home/pve/openwrt/include/toplevel.mk:216: recipe for target 'world' failed
make: *** [world] Error 2
- Valeron70
Ok, may be "update -a" is wrong way.
In my own build, the command "cat /proc/net/wireless" shows empty RSSI statistics.
In your build also empty?
root@OpenWrt:/# cat /proc/net/wireless
Inter-| sta-| Quality | Discarded packets | Missed | WE
face | tus | link level noise | nwid crypt frag retry misc | beacon | 22
root@OpenWrt:/#
It is normal, because mtk official driver do not support standard mac802.11 interface.
maybe later i will write a patch to make it support it.
- Valeron70
After "step-by-step" build 18.06.02 as in "Beginner: OpenWrt 18.06.02 stable version", I got a working firmware with Qt5.
But the debugging process is unavailable, and get this error:
Is it error for Ubuntu gdb or toolchain gdb ?
I think for toolchain gdb. I'm right?
The selected build of GDB does not support Python scripting.
It cannot be used in Qt Creator.
Valeron70 wrote:After "step-by-step" build 18.06.02 as in "Beginner: OpenWrt 18.06.02 stable version", I got a working firmware with Qt5.
You missed one patch for gdb, that patch is used to enable python. openwrt/toolchain/gdb/Makefile, change 'without-python' to 'with-python'
After compile, goto build_dir/.../gdb.../, make install.
Users browsing this forum: No registered users and 73 guests
