I have an application this was developed and currently running on one VoCore2 but when I copy over the application to a new Vocore2 and a VoCore2 that has been updated to the latest firmware (from the latest .bin download) it does not work. It appears to be missing the uClib library files needed for the application. Any thoughts on why this is happening? Shouldn't I be able to develop and app using the OpenWrt development toolchain and it work on the VoCore2 right out of the box?
Firmware is 20191127.
The firmware runs and operates normally, however, my applications that I created do not work. I have even made a simple hello world application and that fails. The error I get is a not found error for the application.
Best,
John
Applications running on new firmware
- john.lusher
- john.lusher
Re: Applications running on new firmware
Solved the issue by using my own OpenWRT build.
Thank you for the report, the toolchain is out of date, I will update it.
Users browsing this forum: No registered users and 4 guests
