Stream h.264 with VoCore camera
Bluesmell
Thu Nov 07, 2019 2:03 pm
I searched everywhere... but is there any tutorial how to stream h264 from Vocore camera with VoCore2 ?
My goal is to stream over UDP to play it back on another device in wired network. How you make it happen´ ?
Followed instructions @ https://vocore.io/v2u.html - and I get stream with MJPG-STREAMER under Luci when my source is /dev/video0 - no picture if i use /dev/video1
So far I can also stream mjpeg from /dev/video0 with ffmpeg: "ffmpeg -f v4l2 -input_format mjpeg -i /dev/video0 -c:v copy -f mjpeg udp://224.1.1.1:15004"
I can playback stream with ffplay from another device on network with high latency. But I need to do the same with h264 stream.
when I try : "ffmpeg -f v4l2 -i /dev/video1 -c:v copy -f mpegts udp://224.1.1.1:15004" I get no error but also no picture from other side.
So ffmpeg package for openwrt has no h264 parser, and codec built-in. Is the only solution to compile ffmpeg with h264 options or is there any other way to do this.
Also does anyone has FFMPEG with h264 also compiled for VoCore2 :)
Maybe my ffmpeg approach is wrong ? lead me some direction.
Thanks. Really need some help.
Re: Stream h.264 with VoCore camera
Fri Nov 08, 2019 1:42 pm
To use h264, please check vocore.io/camera.html download the SDK first, we have a demo source code.
And here is a simple tutorial: http://vonger.cn/?p=14751, http://vonger.cn/?p=14773
I do not know much about ffmpeg and codec, but I think it might be easy for you once you can get h264 data from the demo.
Elliot Hamilton
Sun Mar 01, 2020 3:58 pm
Bluesmell wrote:Hello,
Followed instructions @ https://777spinslot.com/new-casinos/ - and I get stream with MJPG-STREAMER under Luci when my source is /dev/video0 - no picture if i use /dev/video1
I hope you've decided your problem. All the best to you.
Return to VoCam264 & Screen
Users browsing this forum: No registered users and 0 guests
