I moved the PWM0 and PWM1 pins to the right side for a easier rooting on 1 layer.
Here are the gerber files, if you want order to a PCB fusion company (for example seeedstudio with 3 "e"), i changed for a 2 layer PCB, with this you will have the 2 pins PWM0 and PWM1 at the correct place :
Preview :
Gerber files (zip file to give):
https://drive.google.com/open?id=0B0awE ... VhRNlhIdVk
headers for the vocore (step of 50th or 1.27mm) : http://www.ebay.fr/itm/142290958989?var=441340040244
