Hi Guys..
Would it be possible to stream video to a smartphone/tablet app? What modules would be needed?
Video stream to tablet/smartphone
- callumrexreid
Re: Video stream to tablet/smartphone
Of course, but you have to know video codec first.
Or simplest way is the mjepg-streamer, I have a blog about it. able to view in browser.
- deshipu
Make sure you have mjpeg-capable webcam. Mjpg-streamer currently segfaults and crashes with the -yuv option on VoCore.
- Ripple
It crashes on many routers not just vocore, so don't use YUV format. Use a mjpeg video format instead.
If you need a camera that supports it, a good choice would be the Microsoft Lifecam HD 3000.
Also I'd like to mention there are 3 ways to stream that I know of: mjpg-streamer, gstreamer and ffmpeg.
Regards!
Regards!
- Ruphobia
Yep; I have not been able to get yuyv to work on any OpenWRT module; So this isn't a VoCore issue
Any camera that supports UVC + MJPEG should work just fine.
Try this package, it should work with the -y option
http://noblepepper.com/wp/wp-content/vocore-1.0b/packages/mjpg-streamer_r148-4_ramips_24kec.ipk
You should be able to wget it with
and then remove the other one and install it with
cd /root/
wget http://noblepepper.com/wp/wp-content/vocore-1.0b/packages/mjpg-streamer_r148-4_ramips_24kec.ipk
cd -
opkg remove mjpg-streamer
opkg install /root/mjpg-streamer_r148-4_ramips_24kec.ipk
rm /var/opkg-lists/*
Users browsing this forum: No registered users and 23 guests
