No WiFi any more
invliD
No WiFi any more
Mon Feb 29, 2016 1:05 am
Hey all,
I've just received my VoCore recently and started playing around a bit. With the original firmware (Barrier Breaker) everything seemed to work fine. I could access the AP, I even got an 802.11s mesh WiFi working. Since I wanted to add some custom stuff to the firmware I built a new image off current OpenWRT trunk. I installed it using LuCI, everything seemed to work. It booted up fine. But the WiFi never came online.
I suspected it was my firmware, so I tried all of Vonger's firmware images I could find (I tried vocore.bin, vocore16.bin, vocore.v1.0.bin and vocore.dock2.bin), all of them are Chaos Calmer. Still, the issue persists. From the UART console everything looks fine, as if the WiFi would work, but it never shows up on any other devices.
The only thing different is
iw dev wlan0 scan
not producing any output at all and in many cases actually resulting in a kernel oops:
root@OpenWrt:/# iw dev wlan0 scan
[  401.290000] ------------[ cut here ]------------
[  401.300000] WARNING: at /Volumes/VoCore/openwrt/build_dir/target-mipsel_24kec+dsp_uClibc-0.9.33.2/linux-ramips_rt305x/compat-wireless-2014-05-22/drivers/net/wireless/rt2x00/rt2800lib.c:1092 rt2800_conf_tx+0x3c8/0x494 [rt2800lib]()
[  401.340000] Modules linked in: rt2800soc rt2800mmio rt2800lib pppoe ppp_async iptable_nat rt2x00soc rt2x00mmio rt2x00lib pppox ppp_generic nf_nat_ipv4 nf_conntrack_ipv4 mmc_spi mac80211 ipt_MASQUERADE cfg80211 xt_time xt_tcpudp xt_state xt_nat xt_multiport xt_mark xt_mac xt_limit xt_id xt_conntrack xt_comment xt_TCPMSS xt_REDIRECT xt_LOG xt_CT slhc of_mmc_spi nf_nat_irc nf_nat_ftp nf_nat nf_defrag_ipv4 nf_conntrack_irc nf_conntrack_ftp iptable_raw iptable_mangle iptable_filter ipt_REJECT ip_tables crc7 crc16 crc_itu_t crc_ccitt compat sg i2c_ralink of_i2c i2c_core ip6t_REJECT ip6table_raw ip6table_mangle ip6table_filter ip6_tables x_tables nf_conntrack_ipv6 nf_conntrack nf_defrag_ipv6 vfat fat ipv6 eeprom_93cx6 arc4 crypto_blkcipher mmc_block usb_storage mmc_core ohci_hcd ehci_platform ehci_hcd sd_mod scsi_mod usbcore nls_base usb_common crypto_hash
[  401.500000] CPU: 0 PID: 1016 Comm: iw Not tainted 3.10.49 #17
[  401.510000] Stack : 00000000 00000000 00000000 00000000 802fa366 00000031 80d89698 80ef9d40
     802563ec 8029654b 000003f8 802f381c 80d89698 80ef9d40 00000008 0000001c
     00000001 80204410 00000003 80172648 80ef3bd8 80ef9d40 80257a44 81b6b774
     00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
     00000000 00000000 00000000 00000000 00000000 00000000 00000000 81b6b700
[  401.580000] Call Trace:
[  401.580000] [<801ad0e0>] show_stack+0x48/0x70
[  401.590000] [<802147f8>] warn_slowpath_common+0x78/0xa8
[  401.600000] [<802148b0>] warn_slowpath_null+0x18/0x24
[  401.610000] [<80ee4078>] rt2800_conf_tx+0x3c8/0x494 [rt2800lib]
[  401.620000]
[  401.630000] ---[ end trace be6802745103a251 ]---
Any idea what's happening? Can I find the original BB firmware anywhere to test if it's a firmware or hardware issue?
Best,
invliD.
Re: No WiFi any more
Sun Mar 06, 2016 12:46 am
Looks like the factory setting section is not correct, please check partition "factory"
invliD
Sun Jul 10, 2016 4:00 pm
Somehow my last post was never published, so here it is again:
This is my factory partition:
00000000  50 53 00 01 b8 d8 12 66  1e d5 ff ff ff ff ff ff  |PS.....f........|
00000010  ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
00000020  ff ff ff ff ff ff ff ff  b8 d8 12 66 1e d5 b8 d8  |...........f....|
00000030  12 66 1e d5 11 ff 24 10  ff ff 2e 01 55 77 a8 aa  |.f....$.....Uw..|
00000040  8c 88 ff ff 0c 00 00 00  00 00 00 00 00 00 ff ff  |................|
00000050  ff ff 10 10 10 10 10 10  10 10 10 10 10 10 10 10  |................|
00000060  ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
00000070  ff ff ff ff ff ff 03 80  ff ff ff ff ff ff ff ff  |................|
00000080  ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
000000d0  ff ff ff ff ff ff ff ff  ff ff ff ff ff ff 66 66  |..............ff|
000000e0  cc aa 88 66 cc aa 88 66  cc aa 88 66 cc aa 88 66  |...f...f...f...f|
000000f0  ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
00000120  81 09 1c 13 4f 15 4f 15  03 1d 07 1d ff ff ff ff  |....O.O.........|
00000130  ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
How can I tell if there's anything wrong with it?
Mon Jul 11, 2016 4:40 pm
I guess the latest openwrt wifi driver is broken, this happens before :)
Better to use stable version but not latest version.
invliD
Mon Jul 11, 2016 9:31 pm
As I said, I've already tried all your images that I could find. None of them worked. Do you have the original image that was on the vocore somewhere (the Barrier Breaker image)? Is my recovery partition alright?
Tue Jul 12, 2016 8:37 am
The factory setting is correct.
Do you try this one? http://vonger.cn/upload/firmware/vocore.dock2.bin
invliD
Thu Jul 14, 2016 8:12 pm
I did. I tried all images I could find. None of them worked.
Fri Jul 15, 2016 12:43 am
That's weird, never meet such issue before.
invliD
Tue Jul 19, 2016 9:34 pm
Is it possible the wifi hardware somehow died?
Ingmar
Mon Sep 12, 2016 2:15 pm
Is there a solution to this problem?
I have exactly the same symptoms after installing Chaos Calmer (Vocore) and resetting to defaults. No more Wifi (visible on a scan networks. Haven't tried going through the serial yet)
Users browsing this forum: No registered users and 41 guests
