Anyone had done a new openwrt-image yet?
Posted: Fri Dec 05, 2014 8:04 pm
by Greenwire-Elektronik
just wondering whether someone tried to make a new openwrt image and load it onto VoCore? I want to include gpio-keys kernel module - someone got experience to share? Vonger, can you perhaps give a brief howto how to do it?
Rgds,
Jonas
Re: Anyone had done a new openwrt-image yet?
Posted: Sat Dec 06, 2014 2:24 pm
by darksoul
http://o-ak.com/blog/o-ak-tech/openwrt- ... asy-steps/ Step by Step, all tested, all works!
The guide is universal, at the bottom you will find what you need to change for vocode firmware.
Posted: Sat Dec 06, 2014 4:25 pm
darksoul wrote:Just did 15 minutes ago.
Do you want me to write a step-by-step guide?
Sure! I tried to enter the patches i found on the blog but the patch failed finding the correct files. In fact i think a step-by-step-guide should be sticky so everyone can see it - you might consider a new topic for it
Posted: Mon Dec 08, 2014 12:15 pm
by Ripple
Just a quick question. If I want to install a newer version of OpenWRT on VoCore, what's the correct way to do it? Does OpenWRT website offer a pre-built image for this device like it does for many routers? Is there an Image Builder? Or do I have to cross compile everything myself from source?
Best regards!
Posted: Wed Dec 10, 2014 3:50 am
by darksoul
Get the latest fresh image here -
https://downloads.openwrt.org/snapshots/trunk/ramips/openwrt-ramips-rt305x-vocore-squashfs-sysupgrade.binthere are two ways to upgrade, via terminal or luci.
check out the link that i gave earlier there is an example.
Posted: Wed Dec 10, 2014 5:07 am
Posted: Thu Dec 11, 2014 5:48 am
by earlaker
That image will brick your VoCore. Trust me, I just did it
Posted: Fri Dec 12, 2014 5:13 am
by charliex
did it brick it, or just turn off the wifi ? ive used the prebuilt before
Posted: Fri Dec 26, 2014 3:29 am
by pcnate
I installed the image using the web interface using the save config option. It booted fine for me. Only issue is no web interface afterwards, which doesn't bother me as I am uninterested in a web server on anything with less than 100MB ram. I always have the serial connection open anyways.
Posted: Tue Dec 08, 2015 8:37 pm
by fmotta
I have built about 20 different images with differing features.
Other than a likelihood that I will have to recover a board (speculatively) because I made the image too large it works great as documented.
