Doesn't boot automatically
Posted: Wed Dec 10, 2014 7:03 pm
I've been playing with the VoCore, and when I built and uploaded my sysupgrade image, it doesn't start.
This is everything it prints:
However, if I press "x" and manually tell U-boot to boot, it starts correctly:
Does anybody know what's happening?
PS: I did the fix on VOCORE.dts before building.
Version: May 30 2014 20:52:36
Press 'x' to console...
Booting image at bc050000 .
Image Name: MIPS OpenWrt Linux-3.10.49
Created: 2014-12-10 13:02:26 UTC
Data Size: 1006262 Bytes = 982.7 kB
Load Address: 80000000
Entry Point: 80000000
Load Kernel: ................
Verifying Checksum ... OK
[ 0.000000] Linux version 3.10.49 (xavier@xavier-pad) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r43321) ) #1 Wed Dec 10 14:02:19 CET 2014
[ 0.000000] SoC Type: Ralink RT5350 id:1 rev:3
[ 0.000000] CPU revision is: 0001964c (MIPS 24KEc)
[ 0.000000] MIPS: machine is VoCore
[ 0.000000] memory: 02000000 @ 00000000 (usable)
VoCore> bootm bc050000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x00000000-0x01ffffff]
[ 0.000000] node 0: [mem 0x00000000-0x01ffffff]
[ 0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 32 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: console=ttyS0,57600 rootfstype=squashfs,jffs2
[ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Writing ErrCtl register=00042c30
[ 0.000000] Readback ErrCtl register=00042c30
[ 0.000000] Memory: 29348k/32768k available (2162k kernel code, 3420k reserved, 557k data, 156k init, 0k highmem)
[ 0.000000] NR_IRQS:256
[ 0.000000] CPU Clock: 360MHz
[ 0.000000] Calibrating delay loop... 239.61 BogoMIPS (lpj=1198080)
[ 0.070000] pid_max: default: 32768 minimum: 301
[ 0.070000] Mount-cache hash table entries: 512
[ 0.080000] pinctrl core: initialized pinctrl subsystem
[ 0.090000] NET: Registered protocol family 16
[ 0.140000] bio: create slab <bio-0> at 0
[ 0.150000] rt2880_gpio 10000600.gpio: registering 22 gpios
[ 0.160000] rt2880_gpio 10000600.gpio: registering 22 irq handlers
[ 0.170000] rt2880_gpio 10000660.gpio: registering 6 gpios
[ 0.180000] rt2880_gpio 10000660.gpio: registering 6 irq handlers
[ 0.190000] Switching to clocksource MIPS
[ 0.200000] NET: Registered protocol family 2
[ 0.210000] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.230000] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.240000] TCP: Hash tables configured (established 512 bind 512)
[ 0.250000] TCP: reno registered
[ 0.260000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.270000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.280000] NET: Registered protocol family 1
[ 0.290000] rt-timer 10000100.timer: maximum frequncy is 7324Hz
[ 0.350000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.360000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.380000] msgmni has been set to 57
[ 0.390000] io scheduler noop registered
[ 0.400000] io scheduler deadline registered (default)
[ 0.420000] gpio-export gpio-export.4: 17 gpio(s) exported
[ 0.440000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.450000] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 20) is a 16550A
[ 0.470000] console [ttyS0] enabled, bootconsole disabled
[ 0.500000] m25p80 spi32766.0: found w25q128, expected s25fl064k
[ 0.510000] m25p80 spi32766.0: w25q128 (16384 Kbytes)
[ 0.520000] 4 ofpart partitions found on MTD device spi32766.0
[ 0.530000] Creating 4 MTD partitions on "spi32766.0":
[ 0.550000] 0x000000000000-0x000000030000 : "uboot"
[ 0.560000] 0x000000030000-0x000000040000 : "uboot-env"
[ 0.570000] 0x000000040000-0x000000050000 : "factory"
[ 0.590000] 0x000000050000-0x000001000000 : "firmware"
[ 0.600000] 0x000000145af6-0x000001000000 : "rootfs"
[ 0.610000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[ 0.640000] mtd: device 4 (rootfs) set to be root filesystem
[ 0.650000] mtd: partition "rootfs_data" created automatically, ofs=0x330000, len=0xcd0000
[ 0.670000] 0x000000330000-0x000001000000 : "rootfs_data"
[ 0.700000] ralink_soc_eth 10100000.ethernet eth0: ralink at 0xb0100000, irq 5
[ 0.710000] rt3xxx-usbphy usbphy.3: loaded
[ 0.720000] rt2880_wdt 10000120.watchdog: Initialized
[ 0.730000] TCP: cubic registered
[ 0.740000] NET: Registered protocol family 17
[ 0.750000] 8021q: 802.1Q VLAN Support v1.8
[ 0.780000] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[ 0.800000] Freeing unused kernel memory: 156K (802a9000 - 802d0000)
procd: Console is alive
procd: - watchdog -
[ 6.800000] usbcore: registered new interface driver usbfs
[ 6.810000] usbcore: registered new interface driver hub
[ 6.820000] usbcore: registered new device driver usb
[ 6.840000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 6.860000] ehci-platform: EHCI generic platform driver
[ 7.070000] rt3xxx-usbphy usbphy.3: remote usb device wakeup disabled
[ 7.080000] rt3xxx-usbphy usbphy.3: UTMI 16bit 30MHz
[ 7.090000] ehci-platform 101c0000.ehci: EHCI Host Controller
[ 7.100000] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[ 7.120000] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[ 7.150000] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[ 7.160000] hub 1-0:1.0: USB hub found
[ 7.170000] hub 1-0:1.0: 1 port detected
[ 7.180000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 7.190000] ohci-platform 101c1000.ohci: Generic Platform OHCI Controller
[ 7.210000] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[ 7.220000] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[ 7.290000] hub 2-0:1.0: USB hub found
[ 7.300000] hub 2-0:1.0: 1 port detected
[ 7.310000] leds-gpio gpio-leds.5: pins are not configured from the driver
procd: - preinit -
[ 8.430000] rt305x-esw 10110000.esw: link changed 0x00
jffs2 is ready
jffs2 is ready
[ 12.500000] jffs2: notice: (313) jffs2_build_xattr_subsystem: complete building xattr subsystem, 17 of xdatum (0 unchecked, 16 orphan) and 23 of xref (0 dead, 16 orp.
switching to overlay
procd: - early -
procd: - watchdog -
procd: - ubus -
procd: - init -
[ 15.190000] NET: Registered protocol family 10
[ 15.210000] nf_conntrack version 0.5.0 (461 buckets, 1844 max)
[ 15.240000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 15.280000] i2c-ralink 10000900.i2c: loaded
[ 15.300000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
[ 15.320000] Backport generated by backports.git backports-20140320-37-g5c33da0
[ 15.340000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 15.420000] xt_time: kernel timezone is -0000
[ 15.470000] cfg80211: Calling CRDA to update world regulatory domain
[ 15.480000] cfg80211: World regulatory domain updated:
[ 15.490000] cfg80211: DFS Master region: unset
[ 15.500000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 15.520000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 15.540000] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 15.550000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 15.570000] cfg80211: (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
[ 15.590000] cfg80211: (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 15.600000] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 15.620000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 15.630000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 15.750000] PPP generic driver version 2.4.2
[ 15.760000] NET: Registered protocol family 24
[ 15.820000] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5350, rev 0500 detected
[ 15.840000] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5350 detected
procd: - init complete -
