[HowTo]Recover from faulty image using tftpboot
Posted: Mon Dec 29, 2014 1:36 pm
After facing problems with faulty kernel images i searched for a better solution to recover to a running image.
Bad news first: You still need Serial Console.
Good news: You do not need to do Serial hacking or sending the file via UART
First of all, you need a tftp server, i use Tftpd64 by Ph. Jounin (Link).
Now the steps for the easiest way to use it:
Now note the size of the copied image:
That is very easy to use. You can change the tftpboot command and enter your own IP-address and image name if you are not able/do not wish to change your IP address and so on. Further information can be found in "the internet".
To change the ip address of Vocore, use setenv ipaddr [IP ADDRESS].
To change the ip address vocore searches the tftp server, use setenv serverip [IP ADDRESS].
To load a image with a specific name, use tftpboot 0x80100000 [whatevertheimageisnamed] - (0x80100000 is the load address - i am not quite sure whether it is the right spot, but thats what tftpboot choses itself, if no parameter is given)
GreenWire-Elektronik, 2014
- Connect VoCore and your HostPC to Ethernet
- Configure your HostPC to 10.10.10.3
- The image you want to copy should be placed in the right directory, named test.bin
- Boot up VoCore and hit x to enter console
- simply enter tftpboot
- Wait for the image to getting loaded.
- enter erase linux to delete old image
- enter cp.linux [the image size you note down earlier] to copy the loaded image into SPI flash
- enter reset to restart the system
- DONE
