Ethernet Connector
Posted: Wed Nov 12, 2014 3:39 pm
I got VoCore without dock but still want to use ethernet. Soldering is not the problem, the thing is I have some ethernet connectors (RJ45 XFATM9) and, If I am not mistaken, the pins don't match with the connector you've used in the Docks. This makes me wonder if this connector would work even if I wire it correctly. http://vonger.cn/upload/VoCore.dock.sch.pdf shows a different picture than what I saw mine is.
This is the connector I have. It has 2 leds but they aren't shown in this diagram.
Should I use it like that ?
P4TP <-> pin 1
P4TN <-> pin 3
P4RP <-> pin 6
P4RN <-> pin 4
+1.8V <-> pin 2 and pin 5
GND <-> pin 8
P4TP <-> pin 1
P4TN <-> pin 3
P4RP <-> pin 6
P4RN <-> pin 4
GND <-> pin 8
