Needing more detail on getting second UART working
aarobc
Tue Mar 03, 2015 3:30 am
I notice that he's referencing the actual original file at the top:
/include/ "rt5350.dtsi"
That's great and all, so... do I create another dtsi file? dts file? If so, what am I to call it? Does this then require referencing somewhere else in the makefile or perhaps the .config file generated by the menuconfig script?
Please keep in mind a lot of us are new to openWRT; any additional guidance is immensely appreciated.
charliex
Re: Needing more detail on getting second UART working
Mon Mar 09, 2015 5:01 am
dont you just edit vocore.dts ?
Greenwire-Elektronik
Mon Mar 09, 2015 6:06 am
It worked apperantly
ion.dulgheru
Sat Apr 11, 2015 9:56 pm
What voltage does this full UART use?
Is it standard serial voltage, 12V, or it is the Vocore standard GPIO voltage, 3.3 volts?
Sun Apr 12, 2015 4:06 pm
ion.dulgheru wrote:What voltage does this full UART use?
it is 3.3V,, and it is TTL
soso
Thu May 07, 2015 8:29 am
i also want to use the second uart。how can i start it。how can i do with the dts。thanks~
Fri May 08, 2015 3:08 am
check this blog http://vonger.cn/?p=1409
