Anybody got the time and patience to make a library containing the VoCore for Eagle PCB?
The ease and low cost of cheap PCB fab houses now means it would be great to have a part I could include in a design but I just don't have the time!
EAGLE PCB part
- AR560
Re: EAGLE PCB part
You speak about shield pcb?
I create mini eagle library for create shield. But my Vocore doesn't comming for now, and I can't check dimmension and correctness of it.
https://github.com/sash13/own-eagle-lib
Example usage:
Example usage:
- AR560
Re: EAGLE PCB part
Also olimex done their board
Look:
https://olimex.wordpress.com/2014/10/24 ... no-update/
https://github.com/OLIMEX/OLINUXINO/tre ... inuXino-A1
Look:
- Pyrofer
Re: EAGLE PCB part
Thanks for that!!!
I will make a simple breakout board and send to DirtyPCBs asap
You get 10 boards from them so I will either have to order 9 more VoCore boards or find something to do with the spares
- AR560
Re: EAGLE PCB part
Please notice on line around module they on Dimensional layer. Now I updated library and move they on tPlace layer. I create pcb only home and this isn't matter, but for production PCB this has the matter.
- sir66
Re: EAGLE PCB part
Hi!
This is my first try to make something like motor control shield for VoCore using this library. Thanks!
https://github.com/sir66/VoCore-Motor-Shield
https://oshpark.com/profiles/sir066
Connection shield for using Pololu DRV8835 Dual Motor Driver Carrier and S7V7F5 Voltage Regulator with VoCore.
https://www.pololu.com/product/2135
https://www.pololu.com/product/2119
It is beta only, but the first instance seems to work fine.
It is test version with male and female headers, in the future in the future is expected to solder DRV8835 and S7V7F5 directly to the board using male pin headers as wire.
