I would like to do some experiment with u-boot.
How do I flash it?
How to flash u-boot?
- dopesoul
Re: How to flash u-boot?
Very easy.
First, make a writable uboot section(update VOCORE.dts, remove read-only in uboot section, compile and flash to VoCore)
Then, use mtd -e uboot write ubootimage.bin uboot
But if you do not have skill recover the uboot, I do not recommend you do this. Once uboot broken, there is no easy way to recover.
My way is remove flash from VoCore and flash the flash by other hardware.
This is inherently dangerous, you can easily brick the VoCore. If you load a non-functional uboot or there are power problems during the flash you have a brick. I made sure I could load the flash chip directly before I played with the u-boot partition.
Here is some info on how to do this: DANGEROUS STUFF
You may want to check out my revisions of the stock uboot.
- Ton
Hi noblepepper,
I am going to try your dangerous stuff on my bricked vocore. I will use a raspberry instead of the arduino you used.
Which file contains the binary data that has to be flashed into the chip?
There are a couple of files in the /bin/ramips directory, I guess one of them?
- qiqiji
noblepepper‘s DANGEROUS STUFF i have done tons of times with no problem
- ad7zj
Unfortunately the link to noblepepper's wiki is dead - anyone have an alternate source? I want to backup my flash image and then re-flash his latest uboot build to try.
- ad7zj
Alright well I was able to get noblepepper's uboot flashed on and it works - and now I can boot the latest builds of openwrt! One question, maybe vonger knows - when I tried to copy uboot into mtd, it failed - I guess the mtd is locked? How to unlock it?
Well to work around this, I used uboot itself to flash the new uboot image, as is described in "Fix Bricked Vocore" here https://vocore.io/v1.html except instead of erase linux, and cp.linux, I use erase uboot and cp.uboot.
root@OpenWrt:/tmp# mtd -e uboot write uboot.img uboot
Could not get MTD device info from uboot
Can't open device for writing!
Users browsing this forum: No registered users and 63 guests
