Question: How to configure Ethernet on Dock
Posted: Fri Nov 14, 2014 11:57 pm
by winkleink
Just received my VoCore.
It comes configured as a Access Point which works great. But I want to connect it to my router so I can install extra software on it.
How do I configure the Ethernet port to connect to my router using DHCP to get it's own IP address.
Note: I tried modifying the interfaces file and can no longer connect over wifi, so will have to reset using serial next time I switch on.
All tips/ideas and suggested RTFMs appreciated.
Re: Question: How to configure Ethernet on Dock
Posted: Tue Nov 18, 2014 1:02 am
There is a simple way, please set it to AP+STA mode. This might help.
http://vonger.cn/?p=332http://vonger.cn/?p=363http://vonger.cn/?p=377 Not tested on the ethernet
Maybe change /etc/config/network will make it work.
Posted: Tue Nov 18, 2014 5:43 pm
by thebestjohn
Is there a way to do this through the GUI web interface?
Posted: Tue Nov 18, 2014 6:19 pm
by bobpaul
AP+STA mode seems unrelated to the question.
I did this via the web interface:
- Edit Lan Interface
- Disable DHCP Server
- Change protocol from Static address to DHCP Client
Here's an album with screenshots.
Note that this also disables DHCP on your VoCore's WiFi. If you want the VoCore to continue doing DHCP server on the wifi, you need to break the bridge between LAN and WAN and setup the interfaces directly.
Posted: Tue Nov 18, 2014 6:33 pm
by thebestjohn
[s] Is there a way to do this through the web UI at all? [/s]
EDIT: I thought my post was lost. Didn't know you needed moderator approval to ask for help..
Posted: Wed Nov 19, 2014 6:43 pm
by bobpaul
thebestjohn wrote:EDIT: I thought my post was lost. Didn't know you needed moderator approval to ask for help..
Yeah' it's super annoying and makes it really difficult to have conversations. The last 3 posts were all approved simultaneously, which includes your accidental double post.
