Package directory
Posted: Sat Sep 19, 2015 10:23 am
by ingramator
The default vocore installation points to an opkg directory that no longer exits!! It now has sub branches, see
https://downloads.openwrt.org/snapshots/trunk/ramips/ and I've tried generic with no luck. Trying to install python but it's not working
Re: Package directory
Posted: Tue Sep 22, 2015 10:32 am
Hi, you can use the official firmware from openwrt,
https://downloads.openwrt.org/barrier_b ... pgrade.binuse sysupgrade [bin file]. Update your vocore, then every pkg will work.
Posted: Wed Sep 23, 2015 10:10 am
by noblepepper
Here is a more verbose descrition of the
changesThere are other problems that can crop up if you use packages from a build that is different from the image you have on your VoCore.
