Reset setting
Posted: Tue Nov 18, 2014 10:20 pm
by pkedvessy
I'm wondering how I can reset the default setting. I played with interface setting on the web interface and I mixed up something...
After powering up the module there is now vocore wifi network and I get the following signal by the green led on the network plug:
I can see this "message" few times and after that the module seems like restarting itself.
Thanks,
Peter
Re: Reset setting
Posted: Wed Nov 19, 2014 3:28 pm
by Peter H
I think step 2 in the 'getting started' guide should be to configure VoCore to enable SSH and HTTP on the Ethernet interface, so that you have an easy way to connect and put things right if you mess up the WiFi configuration.
If you haven't already done that then you're in the same situation I was in a few days ago. You will need to connect the USB-TTL adapter to your VoCore and use PuTTY or similar terminal emulation to get a command line interface to the VoCore. Then you can edit the configuration files to get things working again.
If you still have a working network interface then you can also use the web interface to download a snapshot of the configuration, and reinstate it. If you have don't have a snapshot of the initial configuration then you take one from another VoCore. Taking a configuration snapshot should be step 1 in the 'getting started guide'.
IMO step 3 should be configuring the WiFi interface as a client, and/or securing the AP. Until you do this, your VoCore provides unrestricted public access to your Ethernet network from the outside world, bypassing all the network protections of your router.
Re: Reset setting
Posted: Wed Nov 19, 2014 11:15 pm
by pkedvessy
I have command line interface by the USB-TTL adapter but no throw any network interface.
Could you please help me to restore the interface configurations or to set up the wifi AP from scratch?
Re: Reset setting
Posted: Thu Nov 20, 2014 12:29 am
by Peter H
At the command prompt set the working directory to /etc/config. The files you need to fix are here. You will need to use the 'vi' editor to edit them. If you aren't familiar with that then expect a painful learning curve, but 'vi' is well known and you should find plenty of tutorials on the internet.
The file you are most likely to need to change is /etc/config/wireless. The example below should get you back to a running AP with no security.
config wifi-device radio0
option type mac80211
option channel 11
option hwmode 11g
option path '10180000.wmac'
option htmode HT20
config wifi-iface
option device radio0
option network lan
option mode ap
option ssid VoCore
option encryption none
After saving the file, run the command 'wifi' to apply the new configuration.
Once you have got WiFi access back I recommend using the LuCI web interface to back up the existing configuration. If your VoCore has an Ethernet port then I recommend you also change the configuration to enable SSH and HTTP connections via Ethernet. From memory, that is as simple as moving the Ethernet virtual network interface from the WAN zone to the LAN zone and LuCI is the easiest way to do that.
Re: Reset setting
Posted: Thu Nov 20, 2014 9:13 pm
by pkedvessy
Thanks a ton! It is working now.
Re: Reset setting
Posted: Wed Dec 03, 2014 4:01 am
by harrisonhjones
I'm having a similar issue. My "vocore" network shows up but I am unable to connect to it.
Here's my /etc/config/wireless
config wifi-device 'radio0'
option type 'mac80211'
option channel '11'
option hwmode '11g'
option htmode 'HT20'
option txpower '20'
option country '00'
config wifi-iface
option device 'radio0'
option network 'lan'
option mode 'ap'
option ssid 'VoCore'
option encryption 'none'
and my /etc/config/network
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fdc4:df4c:3dd2::/48'
config interface 'lan'
option ifname 'eth0.1'
option force_link '1'
option macaddr 'b8:d8:12:60:00:01'
option type 'bridge'
option ipaddr '192.168.61.1'
option netmask '255.255.255.0'
option ip6assign '60'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option ports '0 4 6t'
Any ideas?
