Source to U-boot
Posted: Sat Nov 22, 2014 6:29 am
Where can I find the source to u-boot used in the VoCore?
U-Boot 1.1.3 (Feb 27 2015 - 09:36:47)
Board: Ralink APSoC DRAM: 32 MB
relocate_code Pointer at: 81fb4000
spi_wait_nsec: 42
spi device id: ef 40 18 0 0 (40180000)
Warning: un-recognized chip ID, please update bootloader!
raspi_read: from:30000 len:1000
.raspi_read: from:30000 len:1000
Ralink UBoot Version: 4.0.0.0
ASIC 5350_MP (Port5<->None)
DRAM_CONF_FROM: Boot-Strapping
DRAM_TYPE: SDRAM
DRAM_SIZE: 256 Mbits
DRAM_WIDTH: 16 bits
DRAM_TOTAL_WIDTH: 16 bits
TOTAL_MEMORY_SIZE: 32 MBytes
Flash component: SPI Flash
Date:Feb 27 2015 Time:09:36:47
icache: sets:256, ways:4, linesz:32 ,total:32768
dcache: sets:128, ways:4, linesz:32 ,total:16384
##### The CPU freq = 360 MHZ ####
estimate memory size =32 Mbytes
Please choose the operation:
0
raspi_read: from:50000 len:40
. Image Name: MIPS OpenWrt Linux-3.10.49
Created: 2015-01-22 15:30:19 UTC
Data Size: 1003882 Bytes = 980.4 kB
Load Address: 80000000
Entry Point: 80000000
raspi_read: from:50040 len:f516a
................ Verifying Checksum ... OK
No initrd
## Giving linux memsize in MB, 32
Starting kernel ...
[ 0.000000] Linux version 3.10.49U-Boot 1.1.3 (Mar 17 2015 - 09:18:59)
relocate_code Pointer at: 81fac000
spi_wait_nsec: 42
DRAM_TYPE: SDRAM
DRAM_WIDTH: 16 bits
Date:Mar 17 2015 Time:09:18:59
You chose 8
raspi_read: from:40028 len:6
NetTxPacket = 0x81FE64C0
KSEG1ADDR(NetTxPacket) = 0xA1FE64C0
NetLoop,call eth_halt !
NetLoop,call eth_init !
Trying Eth0 (10/100-M)
Waitting for RX_DMA_BUSY status Start... done
Header Payload scatter function is Disable !!
ETH_STATE_ACTIVE!!
ETH_STATE_ACTIVE!!
HTTP server is starting at IP : 192.168.1.1
HTTP server is ready!
Web Data will be downloaded at 0x80300000 in RAM
Upgrade type: firmware
Upload file size: 3670020 bytes
Loading: #######################################
<snip>
upload size: 0x 380032, expected size: 0x 380004
upload good
HTTP upload is done! Upgrading...
* FIRMWARE UPGRADING *
* DO NOT POWER OFF DEVICE! *
Executing: erase linux; cp.weblinux
Erase linux kernel block !!
From 0x50000 length 0x3B0000
raspi_erase: offs:50000 len:3b0000
Copy linux image from web[3670020 byte] to SPI Flash[0x00050000]....
raspi_write: to:50000 len:380004
HTTP ugrade is done! Rebooting...
