Screen + MPRO + CH32V003
BertramRaven
Fri Aug 02, 2024 3:37 pm
The sim-racing dashboard demonstrator is using a CH32V003 to control WS2182B LED's is an excellent example. However, I have had trouble sourcing a mounted CH32V003 like the one in demonstrator.
I have successfully downloaded and compiled the Vonger/V7B_WS2812B code ready to upload the CH32V003 and have done so to a dev-board. However, the dev-board is not ideal for embedding with the MPRO.
So, I have two questions:
1: Was the CHV32003 board a custom PCB or did you find it available in bulk?
2: Does the Screen+MPRO board require a firmware update to drive the CH32V003 or does it come ready to control it over I2C using the SimHub plugin?
Many thanks.
A
Re: Screen + MPRO + CH32V003
Sat Nov 02, 2024 8:31 am
About your two question:
1. CH32V003 is a customize PCH solution, if you do not want to DIY it, you can ask sales@vocore.io to get already made one.
2. Yes, CH32V003 need to load firmware or it can not work. Also we can load it for you for your easier usage.
Return to VoCam264 & Screen
