Request to Add Mounting Holes for Screws in the PCB Design
liquidtec
Wed Sep 04, 2024 4:51 am
First, I want to thank you for your great work on the VoCore Screens! I have a suggestion that I believe would be beneficial for many users.
Would it be possible to add mounting holes to the PCB, similar to what is shown in the attached image of the Raspberry Pi Camera Module? These holes would allow the board to be easily secured with screws, enhancing the stability of the assembly and making it easier to integrate into various projects.
Currently, I am designing a case for the display, and due to the lack of mounting holes for screws, I will need to use a "USB-C extension to panel" cable. This cable's female end allows for screwing, which compensates for the missing mounting holes on the PCB. Adding these holes would simplify the design process and eliminate the need for such workarounds.
Thank you for considering this request, and I look forward to your response!
Image Image Image
Best regards,
LiquidTec
Re: Request to Add Mounting Holes for Screws in the PCB Desi
Fri Sep 06, 2024 1:55 am
We will add the screw hole to the driver board for next version.
liquidtec
Fri Sep 06, 2024 8:27 pm
I plan to order another screen from you. When do you expect the next version with a screw hole to be available?
Thu Sep 12, 2024 2:17 am
The MPRO board will not have mount hole, we plan make a wireless board based on bluetooth which will mount MPRO board to it, that one will have 2.5mm screw mount hole, it should be in this year.
Return to VoCam264 & Screen
Users browsing this forum: No registered users and 47 guests
