Request to Add Mounting Holes for Screws in the PCB Design
Posted: Wed Sep 04, 2024 4:51 am
First, I want to thank you for your great work on the VoCore Screens! I have a suggestion that I believe would be beneficial for many users.
Would it be possible to add mounting holes to the PCB, similar to what is shown in the attached image of the Raspberry Pi Camera Module? These holes would allow the board to be easily secured with screws, enhancing the stability of the assembly and making it easier to integrate into various projects.
Currently, I am designing a case for the display, and due to the lack of mounting holes for screws, I will need to use a "USB-C extension to panel" cable. This cable's female end allows for screwing, which compensates for the missing mounting holes on the PCB. Adding these holes would simplify the design process and eliminate the need for such workarounds.
Thank you for considering this request, and I look forward to your response!
Best regards,
LiquidTec
Best regards,
LiquidTec
