VoCore2 keeps rebooting, seems broken
ovdleun
Thu Jan 26, 2017 8:18 am
Hi All,
Received my VoCore2 last week and went straight trying it. In the beginning all seems OK. I even got it connected to my home wifi. Because I had some issues with the MAC addresses of the bridge interface (my Juniper router was learning the interface MAC, while the VoCore's IP (dhcp) was on the bridge). Then I made some network configuration change through the GUI and then I was unable to reach it anymore. Then I managed to connect to it by console. I noticed that it was rebooting all the time. Yesterday I managed to boot in failsafe mode, which seems to prevent the rebooting. Then I was able to connect a USB drive with the lastest bin file (20161224.bin); I then copied the file to /tmp/20161224.bin and did a full re-install as mentioned on this website: mtd -e firmware write /tmp/20161224.bin firmware
Then after 30min it was still at "Erasing firmware":
root@(none):~# mtd -e firmware write /tmp/20161224.bin firmware
Unlocking firmware ...
Erasing firmware ...
Even console didn't respond anymore so I reboot it, which of course I expected not to work:
Bad Magic Number,FFFFFFFF
So I executed the steps under "Fix Bricked VoCore2 (uboot alive)", this worked as far that it did boot again. But unfortunately it didn't help to prevent the rebooting.
Full bootlog not attached because I'm unable to attach .txt/.log files, from the moment I started the recover procedure with kermit So I'll post it below. After flashing, it does a soft reset and the boot starts, all the way to the end (hostname). Then after couple of seconds it says done and starts the restart. That specific part is shown below:
==START
[ 36.960000] device ra0 entered promiscuous mode
[ 36.960000] br-lan: port 2(ra0) entered forwarding state
[ 36.970000] br-lan: port 2(ra0) entered forwarding state
[ 37.430000] jffs2_scan_eraseblock(): End of filesystem marker found at 0x0
[ 37.440000] jffs2_build_filesystem(): unlocking the mtd device... done.
[ 37.450000] jffs2_build_filesystem(): erasing all blocks after the end marker...
[ 38.970000] br-lan: port 2(ra0) entered forwarding state
[ 57.090000] random: nonblocking pool is initialized
[ 88.200000] done.
[ 88.210000] jffs2: notice: (1363) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 89.150000] br-lan: port 2(ra0) entered disabled state
[ 89.160000] br-lan: port 1(eth0.1) entered disabled state
[ 89.190000] device eth0.1 left promiscuous mode
[ 89.200000] br-lan: port 1(eth0.1) entered disabled state
[ 89.220000] IPv6: ADDRCONF(NETDEV_UP): eth0.1: link is not ready
[ 89.250000] device ra0 left promiscuous mode
[ 89.250000] br-lan: port 2(ra0) entered disabled state
[ 89.490000] device eth0 left promiscuous mode
[ 91.300000] device eth0.1 entered promiscuous mode
[ 91.300000] device eth0 entered promiscuous mode
[ 91.320000] br-lan: port 1(eth0.1) entered forwarding state
==END
After that it's back at the ralink uboot and all starts over again.
I hope someone can help me in finding the solution, because it made me not being able to use this great device from the moment I received it.
KR
Onno
== FULL LOG:
0: System Load Linux then write to Flash via Serial.
## Ready for binary (kermit) download to 0x80100000 at 115200 bps...
(Back at hostname)
(/Downloads/) C-Kermit>send /Downloads/20161224.bin
(/Downloads/) C-Kermit>c
Connecting to /dev/ttyUSB0, speed 115200
## Total Size = 0x006c0004 = 7077892 Bytes
## Start Addr = 0x80100000
Done!
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM bus: 16 bit
Total memory: 128 MBytes
Flash component: SPI Flash
RESET MT7628 PHY!!!!!!
Please choose the operation:
gpio trigger enabled
GPIO 46 is high
You chose 3
0
Image Name: MIPS OpenWrt Linux-3.18.29
Data Size: 1146194 Bytes = 1.1 MB
Load Address: 80000000
Entry Point: 80000000
Verifying Checksum ... OK
No initrd
Starting kernel ...
[ 0.000000] Linux version 3.18.29 (vocore@ubuntu) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r49378) ) #32 Sat Dec 24 22:01:05 CST 2016
[ 0.000000] Board has DDR2
[ 0.000000] Zone ranges:
[ 0.000000] Kernel command line: console=ttyS2,115200 rootfstype=squashfs,jffs2
[ 0.000000] Writing ErrCtl register=00070931
[ 0.000000] Readback ErrCtl register=00070931
[ 0.000000] Memory: 126340K/131072K available (2530K kernel code, 131K rwdata, 520K rodata, 136K init, 186K bss, 4732K reserved)
[ 0.000000] NR_IRQS:256
[ 0.000000] CPU Clock: 580MHz
[ 0.230000] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[ 0.240000] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[ 0.250000] console [ttyS2] disabled
[ 0.260000] 10000e00.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
[ 0.270000] console [ttyS2] enabled
[ 0.270000] bootconsole [early0] disabled
[ 0.280000] spi-mt7621 10000b00.spi: sys_freq: 193333333
[ 0.290000] m25p80 spi32766.0: found gd25q128, expected en25q64
[ 0.300000] m25p80 spi32766.0: gd25q128 (16384 Kbytes)
[ 0.300000] m25p80 spi32766.0: using chunked io
[ 0.310000] 4 ofpart partitions found on MTD device spi32766.0
[ 0.320000] Creating 4 MTD partitions on "spi32766.0":
[ 0.320000] 0x000000000000-0x000000030000 : "u-boot"
[ 0.330000] 0x000000030000-0x000000040000 : "u-boot-env"
[ 0.330000] 0x000000040000-0x000000050000 : "factory"
[ 0.340000] 0x000000050000-0x000001000000 : "firmware"
[ 0.410000] 2 uimage-fw partitions found on MTD device firmware
[ 0.410000] 0x000000050000-0x000000167d92 : "kernel"
[ 0.420000] 0x000000167d92-0x000001000000 : "rootfs"
[ 0.420000] mtd: device 5 (rootfs) set to be root filesystem
[ 0.430000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.440000] 0x0000006f0000-0x000001000000 : "rootfs_data"
[ 0.450000] ralink_soc_eth 10100000.ethernet: generated random MAC address 7a:76:b5:dc:16:0d
[ 0.460000] ralink_soc_eth 10100000.ethernet eth0: ralink at 0xb0100000, irq 5
[ 0.470000] mt7621_wdt 10000120.watchdog: Initialized
[ 0.480000] TCP: cubic registered
[ 0.480000] NET: Registered protocol family 17
[ 0.480000] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 0.500000] 8021q: 802.1Q VLAN Support v1.8
[ 0.520000] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 0.520000] Freeing unused kernel memory: 136K (8031e000 - 80340000)
[ 2.320000] init: Console is alive
[ 2.320000] init: - watchdog -
[ 5.850000] usbcore: registered new interface driver usbfs
[ 5.860000] usbcore: registered new interface driver hub
[ 5.870000] usbcore: registered new device driver usb
[ 5.880000] exFAT: Version 1.2.9
[ 5.930000] SCSI subsystem initialized
[ 5.940000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.950000] ehci-platform: EHCI generic platform driver
[ 5.970000] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[ 5.970000] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[ 5.980000] ehci-platform 101c0000.ehci: EHCI Host Controller
[ 5.980000] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[ 5.990000] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[ 6.020000] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[ 6.020000] hub 1-0:1.0: USB hub found
[ 6.030000] hub 1-0:1.0: 1 port detected
[ 6.030000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 6.040000] ohci-platform: OHCI generic platform driver
[ 6.050000] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[ 6.050000] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[ 6.060000] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[ 6.130000] hub 2-0:1.0: USB hub found
[ 6.130000] hub 2-0:1.0: 1 port detected
[ 6.150000] MTK MSDC device init.
[ 6.190000] mtk-sd: MediaTek MT6575 MSDC Driver
[ 6.190000] sdhci: Secure Digital Host Controller Interface driver
[ 6.200000] sdhci: Copyright(c) Pierre Ossman
[ 6.210000] sdhci-pltfm: SDHCI platform and OF driver helper
[ 6.220000] usbcore: registered new interface driver usb-storage
[ 6.440000] init: - preinit -
[ 7.700000] rt305x-esw 10110000.esw: link changed 0x00
[ 7.850000] random: procd urandom read with 13 bits of entropy available
[ 11.140000] mount_root: loading kmods from internal overlay
[ 11.660000] block: attempting to load /etc/config/fstab
[ 11.670000] block: unable to load configuration (fstab: Entry not found)
[ 11.670000] block: no usable configuration
[ 11.680000] mount_root: jffs2 not ready yet, using temporary tmpfs overlay
[ 11.700000] procd: - early -
[ 11.710000] procd: - watchdog -
[ 12.570000] procd: - ubus -
[ 13.590000] procd: - init -
[ 15.060000] NET: Registered protocol family 10
[ 15.140000] ntfs: driver 2.1.31 [Flags: R/O MODULE].
[ 15.260000] tun: Universal TUN/TAP device driver, 1.6
[ 15.270000] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 15.300000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 15.350000] i2c /dev entries driver
[ 16.450000] <-- RTMPAllocTxRxRingMemory, Status=0, ErrorValue=0x
[ 16.460000] <-- RTMPAllocAdapterBlock, Status=0
[ 16.490000] i2c-gpio i2c-gpio: using pins 5 (SDA) and 4 (SCL)
[ 16.510000] Linux video capture interface: v2.00
[ 16.540000] mt7628-i2s 10000a00.i2s: loaded, sys freq is 480MHz.
[ 16.540000] es8388_codec_probe
[ 16.550000] set system reference clock(mclk) to 12MHz.
[ 16.560000] mt7628-audio audio-card: es8388-hifi <-> 10000a00.i2s mapping ok
[ 16.570000] mt7628-audio audio-card: load
[ 16.580000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 16.600000] nf_conntrack version 0.5.0 (1976 buckets, 7904 max)
[ 16.630000] usbcore: registered new interface driver usblp
[ 16.640000] usbcore: registered new interface driver uvcvideo
[ 16.650000] USB Video Class driver (1.1.1)
[ 16.670000] xt_time: kernel timezone is -0000
[ 16.690000] PPP generic driver version 2.4.2
[ 16.700000] NET: Registered protocol family 24
[ 24.960000] device eth0.1 entered promiscuous mode
[ 24.960000] device eth0 entered promiscuous mode
[ 25.000000] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[ 25.040000] br-lan: port 1(eth0.1) entered forwarding state
[ 25.220000] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 27.040000] br-lan: port 1(eth0.1) entered forwarding state
[ 27.450000] efuse_probe: efuse = 10000002
[ 27.460000] net ra0: Direct firmware load for mt7628.eeprom failed with error -2
[ 27.460000] net ra0: Falling back to user helper
[ 29.130000] tssi_0_target_pwr_g_band = 35
[ 29.130000] tssi_1_target_pwr_g_band = 35
[ 35.980000] <==== rt28xx_init, Status=0
[ 88.200000] done.
DRAM bus: 16 bit
GPIO 46 is high
You chose 3
0
No initrd
Starting kernel ...
(==SNIP==)
Communications disconnect (Back at hostname)
Re: VoCore2 keeps rebooting, seems broken
Thu Jan 26, 2017 12:23 pm
The firmware is broken, please follow vocore.io/v2, recover bricked vocore2.
ovdleun
Sat Jan 28, 2017 7:52 pm
Vonger wrote:The firmware is broken, please follow vocore.io/v2, recover bricked vocore2.
Hi Vonger,
Thanks for taking the time to reply. As mentioned I've already executed the steps under 'Fix Bricked VoCore2 (uboot alive)'. However still had this problem.
But I'll try again as I see that "vocore.io/v2" redirects to http://vocore.io/v2u.html, but the MD5 is both the same for http://vonger.cn/misc/vocore2/20161224.bin
I'll report back the results.
KR,
Onno.
Sun Jan 29, 2017 1:25 am
Looks like the factory section on vocore2 is broken. so wireless can not load itself, it reboot.
Weird, do you erase the hole flash? or replace the flash?
Please check:
1. check if you have a stable power source for VoCore2. If power is not very stable, when wifi up it will draw a lot of current, cause vocore2 reboot.
2. in safe mode(press f before it boot), call hexdump -C /dev/mtd2, check if factory setting is correct(paste it here)
3. maybe something reboot it in user section, in safe mode, call firstboot -y, try to recover.
ovdleun
Sun Jan 29, 2017 9:12 pm
Hi Vonger,
I've just reloaded the firmware; As there are no instructions on how to load the *.img (flash) file.
I replaced the power source with a 5.1V/2A source, which should provide enough power. It boots again, until suddenly it says:
[ 17.540000] NET: Registered protocol family 24
[ 24.160000] device eth0.1 entered promiscuous mode
[ 24.170000] device eth0 entered promiscuous mode
[ 24.180000] br-lan: port 1(eth0.1) entered forwarding state
[ 25.810000] efuse_probe: efuse = 10000002
[ 26.020000] tssi_0_target_pwr_g_band = 35
[ 26.030000] tssi_1_target_pwr_g_band = 35
and then it reboots.
So on your request I rebooted it to safe mode to get the hexdump:
root@(none):/# hexdump -C /dev/mtd2
00000000 00 00 00 00 b8 d8 12 67 35 e2 00 00 00 00 00 00 |(v.....g5.......|
00000010 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................|
00000000 00 00 00 00 30 00 00 00 b8 d8 12 67 35 e3 b8 d8 |....0......g5...|
00000000 00 00 00 e4 11 34 00 20 ff ff 00 01 00 00 00 00 |.g5..4. ........|
00000000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |..".....0.......|
00000000 00 00 00 00 40 b0 c0 ca 23 00 00 00 40 ca 23 00 |....@...#...@.#.|
00000000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000000a0 c6 c6 c4 c4 c4 c0 c0 c4 c4 c4 c4 c4 c0 c0 00 00 |................|
000000b0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000000c0 00 00 00 00 00 00 00 00 00 1a 22 2a 31 35 01 35 |.........."*15.5|
000000d0 39 40 46 4d 7f 7f 7f 00 00 00 00 00 00 00 00 00 |9@FM............|
000000e0 11 1d 11 1d 1c 35 1c 35 1e 35 1e 35 17 19 17 19 |.....5.5.5.5....|
000000f0 00 00 00 00 c0 00 80 88 0a 00 00 00 00 00 00 00 |................|
00000100 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................|
00000000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 77 00 |..............w.|
00000130 11 1d 11 1d 15 7f 15 7f 17 7f 17 7f 10 3b 10 3b |.............;.;|
00000140 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................|
00010000
Then I also ran the 'firstboot -y' command, without succes. It seems like the wifi seems to trigger something, bad memory part of something, which is causing the reboot. When I boot in safe mode, which doesn't seem to start wifi, it doesn't reboot.
Regards,
Onno.
Mon Jan 30, 2017 12:15 pm
You might need to change a USB cable. It is still power issue.
As I remember this log is from uboot, it is normal, just ignore it.
What is the log following this Warning?
ovdleun
Wed Feb 01, 2017 7:46 am
Hi Vonger,
Ok, so I got it working a lot more stable. Yet replaced the power source again (I already had replaced source and USB cable before), but it also seems one of the two 5V connections I connected to the VoCore was a bit flaky.
Now even got my rebuilded version of the vocore openwrt bin working (needed the cp210x kernel mod, which didn't install with the opkg command, kernel version dependency mismatch).
Earlier you said: "so wireless can not load itself, it reboot."
Do you mean that it's going to reboot when it's unable to connect to my wifi network? If so, why not just restart networking?
KR,
Onno.
Fri Feb 03, 2017 7:28 am
When VoCore2 wifi up, it draws a lot of current, suddenly from 100mA to around 500~600mA in 100ms, if your power source is not stable, it can not draw enough current, then it will reboot.
Once wifi is up, it only require around 140mA.
ovdleun
Sat Feb 04, 2017 4:43 pm
Hi Vonger,
Awesome, thanks for the explanation. It's working stable for the last few hours so I'm happy and even got the additional uarts working which I need for my project. Came across this article: http://vonger.cn/?p=1409 and works perfectly. Thanks again and I'll guess I might order one or two more ;o)
Thanks!
Onno.
Users browsing this forum: No registered users and 26 guests
