Hi everyone
I would like to connect with my new Vocore2 throught MicroUSB connection or even by Rj45
I understood that MicroUSB is a host USB and if I would install the UsbTTL driver in Windows 7 I could connet for the console, but everytime that I try to install de driver for USB I get an error as Code 10.
I would like to know if I could connect to Vocore throught Ethernet - Rj45 .. when I connect the cable I get and IP very strange and If I try to connect by SSH I get an error too..
The only way to connect is throught Wiffi,,
In short words I would like to ling the vocore by wire
thanks in advance
I can't connect to my Vocore throught MicroUSB / USB or Rj45
- Lgonzalez4x4
Re: I can't connect to my Vocore throught MicroUSB / USB or
Yes, you can connect to VoCore by ethernet.
Default VoCore port is in wan mode, if you want to directly connect with computer, you need set it to lan mode.
wan mode can directly connect to router, without any setting.
How do you connect by microUSB? Please send a photo.
- Lgonzalez4x4
Hi Vonger
thank you four help.
I changed the MicroUSB cable and now it Works... I love this device...
I will try later to connect by RJ45 being your recomendations
thank you
thank you
Users browsing this forum: Google [Bot] and 78 guests
