HELP ~, Can't connect to my VoCore2
xjp
Fri Dec 16, 2016 5:35 am
:shock:
Well, that's my first time to use VoCore and I'm a totally green hand,
As I got this little box, I just follow the v2u.html guide and power on it (via the microUSB port on the box to my computer's USB), everything is ok.
I got the "VoCore2" in my computer hotspot list, then I connect it via wifi, the Luci interface and SSH are fine.
Then I plug out VoCore2 from my computer's USB hub after the first try (I just remove it as normal router, I think it's a hot-plugging device),
But now, When I re-power on my VoCore2, the LED lights on, I can also find the "VoCore2" in my computer hotspot list,
but i can't connect it at all, It seems the DHCP service not work and my computer can't get a address
Then I try to find the "/dev/ttyUSBx" or "/dev/ttyACMx" on my system ( xubuntu), but I got nothing
No matter how many times I plug in/out it to my computer, the "dmesg" outputs nothing defferent
Who can help me please!
I totally have no idea about it now, there are my system-shell's outputs with command "dmsg | grep usb" :
null@Precision:/dev$ dmesg | grep usb
[    0.203485] usbcore: registered new interface driver usbfs
[    0.203492] usbcore: registered new interface driver hub
[    0.203506] usbcore: registered new device driver usb
[    0.703167] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.703169] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.703170] usb usb1: Product: EHCI Host Controller
[    0.703171] usb usb1: Manufacturer: Linux 4.4.0-53-generic ehci_hcd
[    0.703172] usb usb1: SerialNumber: 0000:00:1a.0
[    0.719162] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    0.719163] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.719164] usb usb2: Product: EHCI Host Controller
[    0.719165] usb usb2: Manufacturer: Linux 4.4.0-53-generic ehci_hcd
[    0.719166] usb usb2: SerialNumber: 0000:00:1d.0
[    0.720730] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    0.720731] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.720731] usb usb3: Product: xHCI Host Controller
[    0.720732] usb usb3: Manufacturer: Linux 4.4.0-53-generic xhci-hcd
[    0.720733] usb usb3: SerialNumber: 0000:00:14.0
[    0.724121] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    0.724122] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.724122] usb usb4: Product: xHCI Host Controller
[    0.724123] usb usb4: Manufacturer: Linux 4.4.0-53-generic xhci-hcd
[    0.724124] usb usb4: SerialNumber: 0000:00:14.0
[    1.015164] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    1.031119] usb 2-1: new high-speed USB device number 2 using ehci-pci
[    1.035153] usb 3-1: new low-speed USB device number 2 using xhci_hcd
[    1.147569] usb 1-1: New USB device found, idVendor=8087, idProduct=8008
[    1.147571] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.163684] usb 2-1: New USB device found, idVendor=8087, idProduct=8000
[    1.163685] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.167445] usb 3-1: New USB device found, idVendor=045e, idProduct=0039
[    1.167446] usb 3-1: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[    1.167447] usb 3-1: Product: Microsoft 5-Button Mouse with IntelliEye(TM)
[    1.167448] usb 3-1: Manufacturer: Microsoft
[    1.167545] usb 3-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[    1.171751] usbcore: registered new interface driver usbhid
[    1.171751] usbhid: USB HID core driver
[    1.172939] input: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM) as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.0/0003:045E:0039.0001/input/input9
[    1.173037] hid-generic 0003:045E:0039.0001: input,hidraw0: USB HID v1.10 Mouse [Microsoft Microsoft 5-Button Mouse with IntelliEye(TM)] on usb-0000:00:14.0-1/input0
[    1.335196] usb 3-2: new low-speed USB device number 3 using xhci_hcd
[    1.435197] usb 2-1.5: new full-speed USB device number 3 using ehci-pci
[    1.468784] usb 3-2: New USB device found, idVendor=1c4f, idProduct=0002
[    1.468786] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.468787] usb 3-2: Product: USB Keykoard
[    1.468788] usb 3-2: Manufacturer: SIGMACH1P
[    1.468942] usb 3-2: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[    1.468945] usb 3-2: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
[    1.471836] input: SIGMACH1P USB Keykoard as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.0/0003:1C4F:0002.0002/input/input10
[    1.527416] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Keyboard [SIGMACH1P USB Keykoard] on usb-0000:00:14.0-2/input0
[    1.529476] usb 2-1.5: New USB device found, idVendor=8087, idProduct=07dc
[    1.529477] usb 2-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.529734] input: SIGMACH1P USB Keykoard as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.1/0003:1C4F:0002.0003/input/input11
[    1.583372] hid-generic 0003:1C4F:0002.0003: input,hidraw2: USB HID v1.10 Device [SIGMACH1P USB Keykoard] on usb-0000:00:14.0-2/input1
[    1.599207] usb 2-1.8: new full-speed USB device number 4 using ehci-pci
[    1.714097] usb 2-1.8: New USB device found, idVendor=0a5c, idProduct=5800
[    1.714099] usb 2-1.8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.714100] usb 2-1.8: Product: 5880
[    1.714100] usb 2-1.8: Manufacturer: Broadcom Corp
[    1.714101] usb 2-1.8: SerialNumber: 0123456789ABCD
[    1.714252] usb 2-1.8: config 0 descriptor??
[    3.099995] usbcore: registered new interface driver btusb
[    5.781347] audit: type=1400 audit(1481861785.534:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ippusbxd" pid=966 comm="apparmor_parser"
BTW, I ran command "opkg update" and install the shadowsocks-client package when I first try,
but I don't even config it or run it at all, Is there anything wrong?
Re: HELP ~, Can't connect to my VoCore2
Sat Dec 17, 2016 1:02 pm
I heard from Chin your problem solved -- it is because your USB wire do not have DP/DM wires...It just a power charge USB wire. ^_^''
cw5301
Sat Dec 17, 2016 9:25 pm
I have a similar problem.
Vocore2 worked OK out of the box but changes to wifi settings via LuCi did not work. Wifi SSID changed to "OpenWrt" (not "Vocore2" or the SSID I had typed in ("gnat") and wifi security did not work.
I tried reflashing firmware via the LuCi interface. Vocore2 rebooted, but now I cannot connect to it. Dhcpd does not appear to be running on the wireless interface and I cannot connect by setting the client IP address manually.
The DHCP client appears to still be running on the ethernet interface and I can get the Vocore2 to accept an IP address via DHCP on the ethernet interface, but I cannot connect to it.
I tried both a regular USB power supply and powering the Vocore2 via a regular USB cable from a laptop. Using USB power supply, I get "connection refused" when trying to SSH, with power from laptop, I get "connection timed out".
Any ideas how to connect to Vocore2 and fix it?
Thank you
CW
Mon Dec 19, 2016 3:26 am
cw5301 wrote:I have a similar problem.
Thank you
CW
You can connect to by through USB, you can not use ssh, connect by USB you need to use putty(serial port connect) or kermit(serial port connect).
xjp
Tue Dec 20, 2016 4:04 am
Vonger wrote:I heard from Chin your problem solved -- it is because your USB wire do not have DP/DM wires...It just a power charge USB wire. ^_^''
:mrgreen: :mrgreen: yep~ exactly it's my fault, I even didn't realise the deffrences between data-wire and charge-wire before ;) ......
