HELP ~, Can't connect to my VoCore2
Posted: Fri Dec 16, 2016 5:35 am
Well, that's my first time to use VoCore and I'm a totally green hand,
As I got this little box, I just follow the v2u.html guide and power on it (via the microUSB port on the box to my computer's USB), everything is ok.
I got the "VoCore2" in my computer hotspot list, then I connect it via wifi, the Luci interface and SSH are fine.
Then I plug out VoCore2 from my computer's USB hub after the first try (I just remove it as normal router, I think it's a hot-plugging device),
But now, When I re-power on my VoCore2, the LED lights on, I can also find the "VoCore2" in my computer hotspot list,
but i can't connect it at all, It seems the DHCP service not work and my computer can't get a address
Then I try to find the "/dev/ttyUSBx" or "/dev/ttyACMx" on my system ( xubuntu), but I got nothing
No matter how many times I plug in/out it to my computer, the "dmesg" outputs nothing defferent
Who can help me please!
I totally have no idea about it now, there are my system-shell's outputs with command "dmsg | grep usb" :
null@Precision:/dev$ dmesg | grep usb
[ 0.203485] usbcore: registered new interface driver usbfs
[ 0.203492] usbcore: registered new interface driver hub
[ 0.203506] usbcore: registered new device driver usb
[ 0.703167] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.703169] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.703170] usb usb1: Product: EHCI Host Controller
[ 0.703171] usb usb1: Manufacturer: Linux 4.4.0-53-generic ehci_hcd
[ 0.703172] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.719162] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.719163] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.719164] usb usb2: Product: EHCI Host Controller
[ 0.719165] usb usb2: Manufacturer: Linux 4.4.0-53-generic ehci_hcd
[ 0.719166] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.720730] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.720731] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.720731] usb usb3: Product: xHCI Host Controller
[ 0.720732] usb usb3: Manufacturer: Linux 4.4.0-53-generic xhci-hcd
[ 0.720733] usb usb3: SerialNumber: 0000:00:14.0
[ 0.724121] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.724122] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.724122] usb usb4: Product: xHCI Host Controller
[ 0.724123] usb usb4: Manufacturer: Linux 4.4.0-53-generic xhci-hcd
[ 0.724124] usb usb4: SerialNumber: 0000:00:14.0
[ 1.015164] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 1.031119] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 1.035153] usb 3-1: new low-speed USB device number 2 using xhci_hcd
[ 1.147569] usb 1-1: New USB device found, idVendor=8087, idProduct=8008
[ 1.147571] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.163684] usb 2-1: New USB device found, idVendor=8087, idProduct=8000
[ 1.163685] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.167445] usb 3-1: New USB device found, idVendor=045e, idProduct=0039
[ 1.167446] usb 3-1: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ 1.167447] usb 3-1: Product: Microsoft 5-Button Mouse with IntelliEye(TM)
[ 1.167448] usb 3-1: Manufacturer: Microsoft
[ 1.167545] usb 3-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 1.171751] usbcore: registered new interface driver usbhid
[ 1.171751] usbhid: USB HID core driver
[ 1.172939] input: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM) as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.0/0003:045E:0039.0001/input/input9
[ 1.173037] hid-generic 0003:045E:0039.0001: input,hidraw0: USB HID v1.10 Mouse [Microsoft Microsoft 5-Button Mouse with IntelliEye(TM)] on usb-0000:00:14.0-1/input0
[ 1.335196] usb 3-2: new low-speed USB device number 3 using xhci_hcd
[ 1.435197] usb 2-1.5: new full-speed USB device number 3 using ehci-pci
[ 1.468784] usb 3-2: New USB device found, idVendor=1c4f, idProduct=0002
[ 1.468786] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.468787] usb 3-2: Product: USB Keykoard
[ 1.468788] usb 3-2: Manufacturer: SIGMACH1P
[ 1.468942] usb 3-2: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 1.468945] usb 3-2: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 1.471836] input: SIGMACH1P USB Keykoard as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.0/0003:1C4F:0002.0002/input/input10
[ 1.527416] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Keyboard [SIGMACH1P USB Keykoard] on usb-0000:00:14.0-2/input0
[ 1.529476] usb 2-1.5: New USB device found, idVendor=8087, idProduct=07dc
[ 1.529477] usb 2-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.529734] input: SIGMACH1P USB Keykoard as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.1/0003:1C4F:0002.0003/input/input11
[ 1.583372] hid-generic 0003:1C4F:0002.0003: input,hidraw2: USB HID v1.10 Device [SIGMACH1P USB Keykoard] on usb-0000:00:14.0-2/input1
[ 1.599207] usb 2-1.8: new full-speed USB device number 4 using ehci-pci
[ 1.714097] usb 2-1.8: New USB device found, idVendor=0a5c, idProduct=5800
[ 1.714099] usb 2-1.8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.714100] usb 2-1.8: Product: 5880
[ 1.714100] usb 2-1.8: Manufacturer: Broadcom Corp
[ 1.714101] usb 2-1.8: SerialNumber: 0123456789ABCD
[ 1.714252] usb 2-1.8: config 0 descriptor??
[ 3.099995] usbcore: registered new interface driver btusb
[ 5.781347] audit: type=1400 audit(1481861785.534:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ippusbxd" pid=966 comm="apparmor_parser"
BTW, I ran command "opkg update" and install the shadowsocks-client package when I first try,
but I don't even config it or run it at all, Is there anything wrong?
