Loading to SDRAM via TFTP should not update env.
ngc
Sun Dec 18, 2016 6:08 am
My v2u reached to me. Thanks for works.
Now I'm trying new system image with "1: load system code to SDRAM via TFTP".
I noticed a bad point about it.
After loading system image (load ***-sysupgrade.bin as 'uImage'), u-boot said:
NetBootFileXferSize= 00380004
Erasing SPI Flash...
Writing to SPI Flash...
The above messages indicate updating environment variable on SPI FLASH.
It is no needs and u-boot should not update environment vars when only loading to SDRAM, because choice "1" is mainly used for debugging.
Updating endurance of SPI FLASH is not much.
Re: Loading to SDRAM via TFTP should not update env.
Sun Dec 18, 2016 9:54 am
1. It will take writing the flash once per minute for 2 months continuously to reach the MINIMUM flash Erase/Program Endurance. While it is possible to wear out the flash if human interaction (i.e not a program doing this) is required I'm not going to worry about it, I'll just buy a new board at that point.
2. The messages you see indicate Das U-Boot is calling the functions that modify flash, they print a "." on the next line each time they modify a sector. Since there isn't a next line nothing is actually modified.
3. I don't know why you think this is writing the environment variables, but if the u-boot-env partition wears out Das U-Boot will start using compiled in defaults, you won't be able to change environment variables but the VoCore2 will boot up normally.
