I'm trying to configure STA mode in LUCI, not in uci command line.
When I click scan button in LUCI, VoCore2 is disappeared! seems it has been rebooted. I cannot find my VoCore2 any more since that!
Is it a bug? I must use uci command to mange it only?
Now is a problem, how can I fix it?
I tried to connected RST and GND for 8s during power on it, just want to reset it to default, but seems not work.
I tried to connect a usb cable to its TTL. but nothing can find in my computer.
Am I doing wrong? I connect usb cable like this:
USB wire VoCore2
black GND
red 5V
green USB DP
white USB DM
I even tried to switch USB DP and USB DM connection, but still got nothing, cannot see TTL COM port in my computer.
How to connect to TTL?
- ivan_liao
Re: How to connect to TTL?
If you are using VoCore2+Ultimate version, just connect microUSB to your computer, and you will find a new device in your device manager, use putty connect to that port at 115200 8n1, everything will work.
- cory
It shows up as 'COM3' in Win10 and as 'GD32 Virtual Comport in FS Mode' in XP, Win7, and Win8. So what he said apply to win10 only.
- ivan_liao
I have a VoCore2 and a VoCore2 Ultimate.
The one got problem is VoCore2, not Ultimate version.
Don't short wires! I have lost a few that way, the 0.05" spacing makes it easy to do.
I make a breakout board that lets me use 0.1" headers and plugin jumpers and use a cheap pl2303 converter
