"I can't get no", wifi connection! (home ap)
mano1979
Thu Dec 29, 2016 6:27 am
Hello guys,
I got a VoCore2 Ultimate for the holidays and having a hard time setting it up. i cannot seem to connect to my home network. i tried multiple times in different ways (webgui, ssh, serial) but nothing works. I have added my bootprocess output below. maybe someone can find the problem?
root@OpenWrt:/bin/vocoremon# reboot
root@OpenWrt:/bin/vocoremon# [  567.210000] br-lan: port 1(eth0.1) entered disabled state
[  567.240000] device eth0.1 left promiscuous mode
[  567.240000] br-lan: port 1(eth0.1) entered disabled state
[  567.250000] IPv6: ADDRCONF(NETDEV_UP): eth0.1: link is not ready
[  567.480000] device eth0 left promiscuous mode
[  571.480000] reboot: Restarting system
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM bus: 16 bit
Total memory: 128 MBytes
Flash component: SPI Flash
Date:Jun 25 2016  Time:22:54:33
RESET MT7628 PHY!!!!!!
Please choose the operation:
gpio trigger enabled
GPIO 46 is low
 0
   Image Name:   MIPS OpenWrt Linux-3.18.29
   Data Size:    1146194 Bytes =  1.1 MB
   Load Address: 80000000
   Entry Point:  80000000
   Verifying Checksum ... OK
No initrd
Starting kernel ...
[    0.000000] Linux version 3.18.29 (vocore@ubuntu) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r49378) ) #32 Sat Dec 24 22:01:05 CST 2016
[    0.000000] Board has DDR2
[    0.000000] Analog PMU set to hw control
[    0.000000] Digital PMU set to hw control
[    0.000000] SoC Type: MediaTek MT7628AN ver:1 eco:2
[    0.000000] CPU0 revision is: 00019655 (MIPS 24KEc)
[    0.000000] MIPS: machine is VoCore2
[    0.000000]  memory: 08000000 @ 00000000 (usable)
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000-0x07ffffff]
[    0.000000]   node   0: [mem 0x00000000-0x07ffffff]
[    0.000000] Initmem setup node 0 [mem 0x00000000-0x07ffffff]
[    0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
[    0.000000] Kernel command line: console=ttyS2,115200 rootfstype=squashfs,jffs2
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Writing ErrCtl register=000387dc
[    0.000000] Readback ErrCtl register=000387dc
[    0.000000] Memory: 126340K/131072K available (2530K kernel code, 131K rwdata, 520K rodata, 136K init, 186K bss, 4732K reserved)
[    0.000000] NR_IRQS:256
[    0.000000] intc: using register map from devicetree
[    0.000000] CPU Clock: 580MHz
[    0.000000] clocksource_of_init: no matching clocksources found
[    0.000000] Calibrating delay loop... 385.84 BogoMIPS (lpj=1929216)
[    0.060000] pid_max: default: 32768 minimum: 301
[    0.060000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.070000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.070000] pinctrl core: initialized pinctrl subsystem
[    0.080000] NET: Registered protocol family 16
[    0.100000] mt7621_gpio 10000600.gpio: registering 32 gpios
[    0.110000] mt7621_gpio 10000600.gpio: registering 32 gpios
[    0.120000] Switched to clocksource MIPS
[    0.120000] NET: Registered protocol family 2
[    0.130000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.130000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.140000] TCP: Hash tables configured (established 1024 bind 1024)
[    0.140000] TCP: reno registered
[    0.150000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.150000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.160000] NET: Registered protocol family 1
[    0.170000] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.180000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.190000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.200000] msgmni has been set to 246
[    0.210000] io scheduler noop registered
[    0.210000] io scheduler deadline registered (default)
[    0.220000] gdma-mt7628 10002800.gdma: revision: 3, channels: 16
[    0.230000] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[    0.230000] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[    0.240000] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[    0.250000] console [ttyS2] disabled
[    0.260000] 10000e00.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
[    0.270000] console [ttyS2] enabled
[    0.270000] bootconsole [early0] disabled
[    0.280000] spi-mt7621 10000b00.spi: sys_freq: 193333333
[    0.290000] m25p80 spi32766.0: found gd25q128, expected en25q64
[    0.300000] m25p80 spi32766.0: gd25q128 (16384 Kbytes)
[    0.300000] m25p80 spi32766.0: using chunked io
[    0.310000] 4 ofpart partitions found on MTD device spi32766.0
[    0.320000] Creating 4 MTD partitions on "spi32766.0":
[    0.320000] 0x000000000000-0x000000030000 : "u-boot"
[    0.330000] 0x000000030000-0x000000040000 : "u-boot-env"
[    0.330000] 0x000000040000-0x000000050000 : "factory"
[    0.340000] 0x000000050000-0x000001000000 : "firmware"
[    0.410000] 2 uimage-fw partitions found on MTD device firmware
[    0.410000] 0x000000050000-0x000000167d92 : "kernel"
[    0.420000] 0x000000167d92-0x000001000000 : "rootfs"
[    0.420000] mtd: device 5 (rootfs) set to be root filesystem
[    0.430000] 1 squashfs-split partitions found on MTD device rootfs
[    0.440000] 0x0000006f0000-0x000001000000 : "rootfs_data"
[    0.450000] ralink_soc_eth 10100000.ethernet: generated random MAC address ee:31:2d:70:64:3a
[    0.460000] ralink_soc_eth 10100000.ethernet eth0: ralink at 0xb0100000, irq 5
[    0.470000] mt7621_wdt 10000120.watchdog: Initialized
[    0.470000] TCP: cubic registered
[    0.480000] NET: Registered protocol family 17
[    0.480000] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    0.500000] 8021q: 802.1Q VLAN Support v1.8
[    0.510000] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[    0.520000] Freeing unused kernel memory: 136K (8031e000 - 80340000)
[    2.320000] init: Console is alive
[    2.320000] init: - watchdog -
[    5.850000] usbcore: registered new interface driver usbfs
[    5.860000] usbcore: registered new interface driver hub
[    5.870000] usbcore: registered new device driver usb
[    5.880000] exFAT: Version 1.2.9
[    5.930000] SCSI subsystem initialized
[    5.940000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    5.950000] ehci-platform: EHCI generic platform driver
[    5.960000] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[    5.970000] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[    5.980000] ehci-platform 101c0000.ehci: EHCI Host Controller
[    5.980000] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[    5.990000] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[    6.020000] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[    6.020000] hub 1-0:1.0: USB hub found
[    6.030000] hub 1-0:1.0: 1 port detected
[    6.030000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    6.040000] ohci-platform: OHCI generic platform driver
[    6.050000] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[    6.050000] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[    6.060000] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[    6.130000] hub 2-0:1.0: USB hub found
[    6.130000] hub 2-0:1.0: 1 port detected
[    6.150000] MTK MSDC device init.
[    6.190000] mtk-sd: MediaTek MT6575 MSDC Driver
[    6.190000] sdhci: Secure Digital Host Controller Interface driver
[    6.200000] sdhci: Copyright(c) Pierre Ossman
[    6.210000] sdhci-pltfm: SDHCI platform and OF driver helper
[    6.220000] usbcore: registered new interface driver usb-storage
[    6.440000] init: - preinit -
[    7.700000] rt305x-esw 10110000.esw: link changed 0x00
[    7.900000] random: mktemp urandom read with 13 bits of entropy available
[   11.130000] mount_root: loading kmods from internal overlay
[   11.790000] jffs2: notice: (374) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[   11.810000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[   11.830000] block: extroot: not configured
[   11.980000] jffs2: notice: (371) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[   12.000000] mount_root: loading kmods from internal overlay
[   12.520000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[   12.540000] block: extroot: not configured
[   12.540000] mount_root: switching to jffs2 overlay
[   12.580000] procd: - early -
[   12.580000] procd: - watchdog -
[   13.490000] procd: - ubus -
Command failed: Not found
[   14.600000] procd: - init -
[   15.980000] NET: Registered protocol family 10
[   16.050000] ntfs: driver 2.1.31 [Flags: R/O MODULE].
[   16.180000] tun: Universal TUN/TAP device driver, 1.6
[   16.180000] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[   16.200000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   16.230000] i2c /dev entries driver
[   17.300000] <-- RTMPAllocTxRxRingMemory, Status=0, ErrorValue=0x
[   17.310000] <-- RTMPAllocAdapterBlock, Status=0
[   17.340000] i2c-gpio i2c-gpio: using pins 5 (SDA) and 4 (SCL)
[   17.360000] Linux video capture interface: v2.00
[   17.390000] mt7628-i2s 10000a00.i2s: loaded, sys freq is 480MHz.
[   17.400000] es8388_codec_probe
[   17.400000] set system reference clock(mclk) to 12MHz.
[   17.410000] mt7628-audio audio-card: es8388-hifi <-> 10000a00.i2s mapping ok
[   17.420000] mt7628-audio audio-card: load
[   17.430000] ip_tables: (C) 2000-2006 Netfilter Core Team
[   17.450000] nf_conntrack version 0.5.0 (1976 buckets, 7904 max)
[   17.480000] usbcore: registered new interface driver usblp
[   17.500000] usbcore: registered new interface driver uvcvideo
[   17.500000] USB Video Class driver (1.1.1)
[   17.530000] xt_time: kernel timezone is -0000
[   17.550000] PPP generic driver version 2.4.2
[   17.560000] NET: Registered protocol family 24
[   24.690000] device eth0.1 entered promiscuous mode
[   24.690000] device eth0 entered promiscuous mode
[   24.720000] br-lan: port 1(eth0.1) entered forwarding state
[   26.720000] br-lan: port 1(eth0.1) entered forwarding state
[   60.310000] random: nonblocking pool is initialized
Re: "I can't get no", wifi connection! (home ap)
Thu Dec 29, 2016 3:54 pm
everything is normal.
1. first, upgrade your firmware to latest version at vocore.io/v2
2. call firstboot -y recover.
3. follow the step at vocore.io/v2 "AP+STA" mode
mano1979
Thu Dec 29, 2016 11:50 pm
Indeed. that worked. I just realized i was flashing the .bin file wrong. I used to choose option 4 on bootup and then used 'loadb'.
this time i used option 0 on the bootup.
now i have just one last issue.
How to get internet to my vocore. i want to be able to install packages from the repo's
mano1979
Fri Dec 30, 2016 12:02 am
That worked indeed. i tried to update the firmware before but realized i did it wrong. This time everything worked. I am connected to my home network now, but still can't do a opkg update.
i have the terminal output below:
  * 1 1/2 oz Gin            Shake with a glassful
  * 1/4 oz Triple Sec       of broken ice and pour
  * 3/4 oz Lime Juice       unstrained into a goblet.
  * 1 1/2 oz Orange Juice
  * 1 tsp. Grenadine Syrup
root@OpenWrt:~# ifconfig
apcli0    Link encap:Ethernet  HWaddr BA:D8:12:07:0C:1B
          inet addr:192.168.192.29  Bcast:192.168.192.255  Mask:255.255.255.0
          inet6 addr: fe80::b8d8:12ff:fe07:c1b/64 Scope:Link
          RX packets:0 errors:0 dropped:834 overruns:0 frame:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
br-lan    Link encap:Ethernet  HWaddr B8:D8:12:67:0C:1B
          inet addr:192.168.61.1  Bcast:192.168.61.255  Mask:255.255.255.0
          inet6 addr: fe80::bad8:12ff:fe67:c1b/64 Scope:Link
          inet6 addr: fd71:aab0:f39b::1/60 Scope:Global
          RX packets:689 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1548 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:79802 (77.9 KiB)  TX bytes:232686 (227.2 KiB)
eth0      Link encap:Ethernet  HWaddr AA:FE:40:A4:B6:2D
          inet6 addr: fe80::a8fe:40ff:fea4:b62d/64 Scope:Link
          TX packets:3832 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:1118265 (1.0 MiB)
          Interrupt:5
eth0.1    Link encap:Ethernet  HWaddr AA:FE:40:A4:B6:2D
          TX packets:572 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:77484 (75.6 KiB)
eth0.2    Link encap:Ethernet  HWaddr B8:D8:12:67:0C:1C
          inet6 addr: fe80::bad8:12ff:fe67:c1c/64 Scope:Link
          TX packets:2613 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:875572 (855.0 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:1310 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1310 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:93024 (90.8 KiB)  TX bytes:93024 (90.8 KiB)
ra0       Link encap:Ethernet  HWaddr B8:D8:12:67:0C:1B
          RX packets:925756 errors:12 dropped:0 overruns:0 frame:0
          TX packets:4100312 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:95047199 (90.6 MiB)  TX bytes:2020267375 (1.8 GiB)
          Interrupt:6
root@OpenWrt:~# ping google.com
PING google.com (216.58.212.142): 56 data bytes
64 bytes from 216.58.212.142: seq=0 ttl=55 time=11.258 ms
64 bytes from 216.58.212.142: seq=1 ttl=55 time=39.798 ms
64 bytes from 216.58.212.142: seq=2 ttl=55 time=10.556 ms
64 bytes from 216.58.212.142: seq=3 ttl=55 time=13.145 ms
64 bytes from 216.58.212.142: seq=4 ttl=55 time=12.867 ms
64 bytes from 216.58.212.142: seq=5 ttl=55 time=12.575 ms
64 bytes from 216.58.212.142: seq=6 ttl=55 time=12.294 ms
64 bytes from 216.58.212.142: seq=7 ttl=55 time=12.003 ms
64 bytes from 216.58.212.142: seq=8 ttl=55 time=11.752 ms
64 bytes from 216.58.212.142: seq=9 ttl=55 time=11.414 ms
64 bytes from 216.58.212.142: seq=10 ttl=55 time=10.265 ms
64 bytes from 216.58.212.142: seq=11 ttl=55 time=10.793 ms
64 bytes from 216.58.212.142: seq=12 ttl=55 time=29.290 ms
64 bytes from 216.58.212.142: seq=13 ttl=55 time=10.314 ms
^C
--- google.com ping statistics ---
14 packets transmitted, 14 packets received, 0% packet loss
round-trip min/avg/max = 10.265/14.880/39.798 ms
root@OpenWrt:~# opkg update
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/packages/base/Packages.gz.
Updated list of available packages in /var/opkg-lists/chaos_calmer_base.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/packages/base/Packages.sig.
Signature check passed.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/packages/linkit/Packages.gz.
wget: server returned error: HTTP/1.1 404 Not Found
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/packages/linkit/Packages.sig.
Signature check failed.
Remove wrong Signature file.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/packages/luci/Packages.gz.
Updated list of available packages in /var/opkg-lists/chaos_calmer_luci.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/packages/luci/Packages.sig.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/packages/packages/Packages.gz.
Updated list of available packages in /var/opkg-lists/chaos_calmer_packages.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/packages/packages/Packages.sig.
Collected errors:
 * opkg_download: Failed to download http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/packages/linkit/Packages.gz, wget returned 1.
 * opkg_download: Failed to download http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/packages/linkit/Packages.sig, wget returned 1.
root@OpenWrt:~#
Fri Dec 30, 2016 12:46 pm
This version opkg is broken, in Jan we will make one version with normal opkg, please upgrade firmware later.
mano1979
Fri Dec 30, 2016 10:07 pm
Actually, i found that the folder 'linkit' is missing from the repo.
Sat Dec 31, 2016 12:39 am
IT WILL REALLY HELP EVERYONE IF YOU START A NEW THREAD FOR A NEW PROBLEM. This has nothing to do with not being able to get a wifi connection so it is just noise on that subject and won't be easily found by people having problems with opkg.
Think of a forum as a set of problems and their solutions, not as a journal of your adventures getting your vocore to work!
Opkg will work just fine like this but you may run into problems with some packages that check to see if they came from the same the same compile run. See this thread for details about that.
You can just delete this line
src/gz chaos_calmer_linkit http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/packages/linkit
from /etc/opkg/distfeeds.conf if the message bothers you. All it means is opkg can't find that repo and won't load packages from the repo (that doesn't exist anyway).
Sat Dec 31, 2016 1:52 am
noblepepper wrote:IT WILL REALLY HELP EVERYONE IF YOU START A NEW THREAD FOR A NEW PROBLEM. This has nothing to do with not being able to get a wifi connection so it is just noise on that subject and won't be easily found by people having problems with opkg.
Sure, add a FAQ topic.
mano1979
Sat Dec 31, 2016 4:39 pm
@noblepepper
No need to shout! I understand... though i agree with @vonger
Users browsing this forum: No registered users and 238 guests
