wifi wpa2 psk length >51 does not work? - Solved
kosmonaut pirx
Tue Jan 03, 2017 10:20 pm
hello,
got my vocore2 last year already, starting to use it finally. First catch, however, wifi connection between vorcore and hostapd can't be established.
After several ours (first suspect always: special chars) figured out, wpa2 psk key length seems to be a problem. Simple example (hostapd.conf snippet):
## does not work, 52chars
wpa_passphrase=0123456789012345678901234567890123456789012345678901
## works, 51chars
Inserted appropriate counterpart at /etc/config/wireless at the vocore, of course.
I don't want to change the key just for this 'cause of other stations. So, maybe anyone can confirm and/or has a workaround at hand?
Of course, already searched for the net a lot.
As there are exactly 12chars missing to max of 63chars, I suspect bssid (default: mac-address, 12chars) is perhaps related in some way..
thanks&regards
Last edited by kosmonaut pirx on Thu Jan 05, 2017 9:43 pm, edited 1 time in total.
Re: wifi wpa2 psk length >51 does not work?
Wed Jan 04, 2017 12:47 am
Oh? where do you setup this? i do not know this yet :)
kosmonaut pirx
Wed Jan 04, 2017 8:27 pm
hello,
the AP is running hostapd, so it's under my direct control. I may change anything there in the corresponding conf file. At vocore it's the usual wirelesl-config file
Setup:
AP: running Gentoo Linux
4.7.0-rc2-g3058387 #9 SMP PREEMPT Sun Jul 10 12:48:03 CEST 2016 armv7l SAMSUNG EXYNOS (Flattened Device Tree) GNU/Linux
Hostapd
net-wireless/hostapd
Latest version available: 2.5
Latest version installed: 2.5
STA: Vocore2
root@OpenWrt:/# uname -a
Linux OpenWrt 3.18.29 #32 Sat Dec 24 22:01:05 CST 2016 mips GNU/Linux
I just checked a different AP (my phone) and same behavior: said 51char psk key and vocore connects, 52char psk key no connection.
Other stations (RPi, Phone)connect to said AP without problems since a year or more.
Part of /etc/config/wireless looks like this:
config wifi-iface 'sta'
        option device 'radio0'
        option mode 'sta'
        option network 'wwan'
        option ifname 'apcli0'
#      example ssid
        option ssid 'jolla'
        option key '012345678901234567890123456789012345678901234567890'
        option encryption 'psk2+ccmp'
I noticed wifi connection is build up with the help of some kind /sbin/ap_client, which is a binary provided by mtk-sdk-wifi, kind of MediaTek soft, I guess. Did try a replacement, but the known wpa_supplicant does not work unfortunately
regards
kosmonaut pirx
Wed Jan 04, 2017 9:04 pm
Some more investigations and kind-of success.
There's most likely something wrong in the used mediatek binary. Looking at some kind of code found here:
https://github.com/MediaTek-Labs/linkit-smart-7688-feed/blob/master/mtk-sdk-wifi/src/ap_client.c
It uses ioctls via 'iwpriv'. So i did the some from cli:
root@OpenWrt:/# iwpriv apcli0 set ApCliWPAPSK='0123456789012345678901234567890123456789012345678901'
and voila, immediate connection :!:
I guess using a 64char buf is not enough in
[code]
static void iwpriv(const char *name, const char *key, const char *val):
[char data[64];
snprintf(data, 64, "%s=%s", key, val);/code]
This explains the missing 12 chars: "ApCliWPAPSK" is 11chars and the '=' is number 12
@Vonger: Where may I get the source of the mtk-sdk-wifi you sue to check for a patch working? Afterwards I'll close this as solved.
Thu Jan 05, 2017 12:39 am
Wi-Fi driver from mediatek is not open source yet. :( Current one is from Linkit.
kosmonaut pirx
Thu Jan 05, 2017 9:41 pm
That's exactly what I suspected :(
so maybe the board needs to be patched after each firmware update for this, but maybe it's even possible via rc.local.
Thanks a lot.
