Vocore2 ultimate factory problem?
irinelturturea
Sat Jan 07, 2017 10:02 am
Hi
My vocore2 arrived but it only works when its is out from the case
The first 2 pictures show how bad the 2 boards fit together and in the last one you can see how misaligned us the audio port with the case.
When I try to align the Ethernet port and the audio port and close the case the 2 boards disconnect from each other and vocore does not start.
Anyone else experienced this problem ?
Re: Vocore2 ultimate factory problem?
Sat Jan 07, 2017 10:44 am
1. insert the 3.5mm headphone to the audio port.
2. correct its position, align it.
3. push at another side, insert the audio port to the shell hole.
irinelturturea
Sat Jan 07, 2017 1:48 pm
Yeah
I tried but when i do that the 2 boards disconect from eachother and then vocore board is not getting power anymore. I susspect also other pins will not be proprely plugged between the 2 boards.
Sun Jan 08, 2017 1:11 am
irinelturturea wrote:Yeah
cory
Sun Jan 08, 2017 5:03 pm
your best option is to go to local high school, look for some science teacher preferably in robotic field, ash him to 'fix' the board for you.
Users browsing this forum: No registered users and 236 guests
