Setup AP + STA Mode
Posted: Sun Jan 08, 2017 3:35 pm
by herci
I tried to setup AP and STA, assuming this means if I'm connected with my vocore for airplay I can still surf on the internet because vocore is a sort of wifi extending point. Let's hope I got this right.
I did the following from the tutorial
I opened Putty
then I copy pasted in parts the following:
uci set wireless.sta.ssid=[the name of my network]
uci set wireless.sta.key=[password of my wifi network]
uci set wireless.sta.network=wwan
uci commit
/etc/init.d/network restart
then this:
sleep 10
uci commit
then;
uci delete network.wwan
uci set network.wwan=interface
uci set network.wwan.proto=dhcp
uci commit
finally:
uci del_list firewall.@zone[1].network=wwan
uci add_list firewall.@zone[1].network=wwan
uci set firewall.@zone[1].input=ACCEPT
uci set firewall.@zone[1].output=ACCEPT
uci set firewall.@zone[1].forward=ACCEPT
uci set firewall.@zone[1].masq=1
uci set firewall.@zone[1].mtu_fix=1
uci commit
I tried it with my wifi extender (it is WPA2). I also tried it with my original router not sure if that one is wpa or wpa 2
But it doesn't seem to work.
Re: Setup AP + STA Mode
Posted: Sun Jan 08, 2017 4:39 pm
by kosmonaut pirx
hello,
you should check what's wrong in detail.
As you have ssh access already, I'd recommend to have a separate session running the command
logread -f
always at hand. So you see what's happening.
In an additional ssh session try your setup. The logread at the other session should show something like this
kern.info ap_client: Found network, trying to associate (essid: ... etc pp
daemon.notice netifd: wan (1483): Sending discover...
kern.info ap_client: apcli0 is associated
daemon.notice netifd: Network device 'apcli0' link is up
daemon.notice netifd: Interface 'wifi_sta' is enabled
daemon.notice netifd: Interface 'wifi_sta' has link connectivity
daemon.notice netifd: Interface 'wifi_sta' is setting up now
(my network is called 'wifi_sta', the tutorial uses 'wwan')
So first check if you're associated with yourr AP at least.
If not, you don't need to check any further, nothing will work.
Otherwise, you're associated with the AP, but for some reason it denies you. Check encryption required by AP, check the key and/or use a simple example key if possible (for this, you changed the key at the AP as well, don't you?)
Check with a reboot (for windows users) or a simple 'wifi' command at ssh/putty console.
Hth, regards
Posted: Sun Jan 08, 2017 8:54 pm
by herci
not sure how to: try my setup
I tried all the command again with logread on
then I started again with the usb cable and typed wifi
this is what I got
root@OpenWrt:~# logread -f
Sat Dec 24 14:10:24 2016 authpriv.warn dropbear[1354]: Login attempt for nonexis tent user from 192.168.1.146:49279
Sat Dec 24 14:10:28 2016 authpriv.warn dropbear[1354]: Login attempt for nonexis tent user from 192.168.1.146:49279
Sat Dec 24 14:10:47 2016 authpriv.warn dropbear[1354]: Login attempt for nonexistent user from 192.168.1.146:49279
Sat Dec 24 14:10:58 2016 authpriv.info dropbear[1354]: Exit before auth: Exited normally
Sat Dec 24 14:11:00 2016 daemon.info dnsmasq-dhcp[1291]: DHCPINFORM(br-lan) 192.168.1.146 10:0b:a9:37:ca:30
Sat Dec 24 14:11:00 2016 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168.1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Sat Dec 24 14:11:21 2016 authpriv.info dropbear[1361]: Child connection from 192.168.1.146:49280
Sat Dec 24 14:11:28 2016 authpriv.notice dropbear[1361]: Password auth succeeded for 'root' from 192.168.1.146:49280
Sat Dec 24 14:13:57 2016 kern.warn kernel: [ 300.720000] /openwrt/CC/build_dir/ target-mipsel_24kec+dsp_uClibc-0.9.33.2/linux-ramips_mt7688/mt7628-4.0.1.3/mt_wi fi_ap/../mt_wifi/embedded/os/linux/ap_ioctl.c:rt28xx_ap_ioctl[265]
Sat Dec 24 14:13:57 2016 kern.warn kernel: [ 300.990000] /openwrt/CC/build_dir/ target-mipsel_24kec+dsp_uClibc-0.9.33.2/linux-ramips_mt7688/mt7628-4.0.1.3/mt_wi fi_ap/../mt_wifi/embedded/os/linux/ap_ioctl.c:rt28xx_ap_ioctl[265]
Sat Dec 24 14:13:57 2016 kern.warn kernel: [ 301.270000] /openwrt/CC/build_dir/ target-mipsel_24kec+dsp_uClibc-0.9.33.2/linux-ramips_mt7688/mt7628-4.0.1.3/mt_wi fi_ap/../mt_wifi/embedded/os/linux/ap_ioctl.c:rt28xx_ap_ioctl[265]
Sat Dec 24 14:15:45 2016 daemon.info dnsmasq-dhcp[1291]: DHCPINFORM(br-lan) 192. 168.1.146 10:0b:a9:37:ca:30
Sat Dec 24 14:15:45 2016 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168 .1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Sat Dec 24 14:22:31 2016 daemon.notice netifd: Interface 'lan' is now down
Sat Dec 24 14:22:31 2016 daemon.info avahi-daemon[1157]: Registering new address record for fe80::bad8:12ff:fe67:13e0 on br-lan.*.
Sat Dec 24 14:22:31 2016 daemon.info avahi-daemon[1157]: Withdrawing address rec ord for 192.168.1.1 on br-lan.
Sat Dec 24 14:22:31 2016 daemon.info avahi-daemon[1157]: Leaving mDNS multicast group on interface br-lan.IPv4 with address 192.168.1.1.
Sat Dec 24 14:22:31 2016 daemon.info avahi-daemon[1157]: Interface br-lan.IPv4 n o longer relevant for mDNS.
Sat Dec 24 14:22:31 2016 kern.info kernel: [ 815.020000] br-lan: port 2(ra0) en tered disabled state
Sat Dec 24 14:22:31 2016 kern.info kernel: [ 815.030000] br-lan: port 1(eth0.1) entered disabled state
Sat Dec 24 14:22:31 2016 daemon.info avahi-daemon[1157]: Interface br-lan.IPv6 n o longer relevant for mDNS.
Sat Dec 24 14:22:31 2016 daemon.info avahi-daemon[1157]: Leaving mDNS multicast group on interface br-lan.IPv6 with address fd1c:5a88:47dd::1.
Sat Dec 24 14:22:31 2016 kern.info kernel: [ 815.050000] device eth0.1 left pro miscuous mode
Sat Dec 24 14:22:31 2016 kern.info kernel: [ 815.050000] br-lan: port 1(eth0.1) entered disabled state
Sat Dec 24 14:22:31 2016 kern.info kernel: [ 815.060000] IPv6: ADDRCONF(NETDEV_ UP): eth0.1: link is not ready
Sat Dec 24 14:22:31 2016 daemon.info avahi-daemon[1157]: Withdrawing address rec ord for fd1c:5a88:47dd::1 on br-lan.
Sat Dec 24 14:22:31 2016 daemon.info avahi-daemon[1157]: Withdrawing address rec ord for fe80::bad8:12ff:fe67:13e0 on br-lan.
Sat Dec 24 14:22:31 2016 kern.info kernel: [ 815.090000] device ra0 left promis cuous mode
Sat Dec 24 14:22:31 2016 kern.info kernel: [ 815.090000] br-lan: port 2(ra0) en tered disabled state
Sat Dec 24 14:22:31 2016 daemon.notice netifd: Interface 'lan' is disabled
Sat Dec 24 14:22:31 2016 daemon.notice netifd: VLAN 'eth0.1' link is down
Sat Dec 24 14:22:31 2016 daemon.notice netifd: Bridge 'br-lan' link is down
Sat Dec 24 14:22:31 2016 daemon.notice netifd: Interface 'lan' has link connecti vity loss
Sat Dec 24 14:22:31 2016 daemon.notice netifd: Interface 'loopback' is now down
Sat Dec 24 14:22:31 2016 daemon.notice netifd: Interface 'loopback' is disabled
Sat Dec 24 14:22:31 2016 daemon.notice netifd: Network device 'lo' link is down
Sat Dec 24 14:22:31 2016 daemon.notice netifd: Interface 'loopback' has link con nectivity loss
Sat Dec 24 14:22:31 2016 daemon.info dnsmasq[1291]: read /etc/hosts - 1 addresse s
Sat Dec 24 14:22:31 2016 daemon.info dnsmasq[1291]: read /tmp/hosts/odhcpd - 0 a ddresses
Sat Dec 24 14:22:31 2016 daemon.info dnsmasq[1291]: read /tmp/hosts/dhcp - 1 add resses
Sat Dec 24 14:22:31 2016 daemon.info dnsmasq-dhcp[1291]: read /etc/ethers - 0 ad dresses
Sat Dec 24 14:22:31 2016 daemon.notice netifd: wan (1043): Received SIGTERM
Sat Dec 24 14:22:31 2016 daemon.notice netifd: Interface 'wan' is now down
Sat Dec 24 14:22:31 2016 daemon.notice netifd: Interface 'wan6' is now down
Sat Dec 24 14:22:31 2016 daemon.info avahi-daemon[1157]: Interface eth0.2.IPv6 n o longer relevant for mDNS.
Sat Dec 24 14:22:31 2016 daemon.info avahi-daemon[1157]: Leaving mDNS multicast group on interface eth0.2.IPv6 with address fe80::bad8:12ff:fe67:13e1.
Sat Dec 24 14:22:31 2016 kern.info kernel: [ 815.360000] device eth0 left promi scuous mode
Sat Dec 24 14:22:31 2016 daemon.notice netifd: Interface 'wan' is disabled
Sat Dec 24 14:22:31 2016 daemon.notice netifd: Interface 'wan6' is disabled
Sat Dec 24 14:22:31 2016 daemon.notice netifd: VLAN 'eth0.2' link is down
Sat Dec 24 14:22:31 2016 daemon.notice netifd: Interface 'wan' has link connecti vity loss
Sat Dec 24 14:22:31 2016 daemon.notice netifd: Interface 'wan6' has link connect ivity loss
Sat Dec 24 14:22:31 2016 daemon.notice netifd: Network device 'eth0' link is dow n
Sat Dec 24 14:22:31 2016 daemon.info avahi-daemon[1157]: Withdrawing address rec ord for fe80::bad8:12ff:fe67:13e1 on eth0.2.
Sat Dec 24 14:22:31 2016 daemon.info avahi-daemon[1157]: Interface eth0.IPv6 no longer relevant for mDNS.
Sat Dec 24 14:22:31 2016 daemon.info avahi-daemon[1157]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::3c30:52ff:fe26:3562.
Sat Dec 24 14:22:31 2016 daemon.info avahi-daemon[1157]: Withdrawing address rec ord for fe80::3c30:52ff:fe26:3562 on eth0.
Sat Dec 24 14:22:33 2016 user.notice root: drv_ralink_cleanup
Sat Dec 24 14:22:33 2016 kern.info kernel: [ 817.130000] device eth0.1 entered promiscuous mode
Sat Dec 24 14:22:33 2016 kern.info kernel: [ 817.140000] device eth0 entered pr omiscuous mode
Sat Dec 24 14:22:33 2016 kern.info kernel: [ 817.160000] br-lan: port 1(eth0.1) entered forwarding state
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Interface 'lan' is enabled
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Interface 'lan' is setting up now
Sat Dec 24 14:22:33 2016 daemon.info avahi-daemon[1157]: Joining mDNS multicast group on interface br-lan.IPv4 with address 192.168.1.1.
Sat Dec 24 14:22:33 2016 daemon.info avahi-daemon[1157]: New relevant interface br-lan.IPv4 for mDNS.
Sat Dec 24 14:22:33 2016 daemon.info avahi-daemon[1157]: Registering new address record for 192.168.1.1 on br-lan.IPv4.
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Interface 'lan' is now up
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Interface 'loopback' is enabled
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Interface 'loopback' is setting u p now
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Interface 'loopback' is now up
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Interface 'wan' is enabled
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Interface 'wan' is setting up now
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Interface 'wan6' is enabled
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Bridge 'br-lan' link is up
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Interface 'lan' has link connecti vity
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Network device 'eth0' link is up
Sat Dec 24 14:22:33 2016 daemon.notice netifd: VLAN 'eth0.1' link is up
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Network device 'lo' link is up
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Interface 'loopback' has link con nectivity
Sat Dec 24 14:22:33 2016 daemon.notice netifd: VLAN 'eth0.2' link is up
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Interface 'wan' has link connecti vity
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Interface 'wan6' has link connect ivity
Sat Dec 24 14:22:33 2016 daemon.notice netifd: Interface 'wan6' is setting up no w
Sat Dec 24 14:22:33 2016 daemon.notice netifd: wan (1543): udhcpc (v1.23.2) star ted
Sat Dec 24 14:22:34 2016 daemon.notice netifd: radio0 (1522): Interface doesn't accept private ioctl...
Sat Dec 24 14:22:34 2016 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Sat Dec 24 14:22:34 2016 daemon.notice netifd: radio0 (1522): set (8BE2): Invali d argument
Sat Dec 24 14:22:34 2016 daemon.notice netifd: wan (1543): Sending discover...
Sat Dec 24 14:22:34 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:22:34 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:22:34 2016 daemon.info avahi-daemon[1157]: Joining mDNS multicast group on interface br-lan.IPv6 with address fd1c:5a88:47dd::1.
Sat Dec 24 14:22:34 2016 daemon.info avahi-daemon[1157]: New relevant interface br-lan.IPv6 for mDNS.
Sat Dec 24 14:22:34 2016 daemon.info avahi-daemon[1157]: Registering new address record for fd1c:5a88:47dd::1 on br-lan.*.
Sat Dec 24 14:22:34 2016 daemon.info avahi-daemon[1157]: Joining mDNS multicast group on interface eth0.2.IPv6 with address fe80::bad8:12ff:fe67:13e1.
Sat Dec 24 14:22:34 2016 daemon.info avahi-daemon[1157]: New relevant interface eth0.2.IPv6 for mDNS.
Sat Dec 24 14:22:34 2016 daemon.info avahi-daemon[1157]: Registering new address record for fe80::bad8:12ff:fe67:13e1 on eth0.2.*.
Sat Dec 24 14:22:35 2016 daemon.info avahi-daemon[1157]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::3c30:52ff:fe26:3562.
Sat Dec 24 14:22:35 2016 daemon.info avahi-daemon[1157]: New relevant interface eth0.IPv6 for mDNS.
Sat Dec 24 14:22:35 2016 daemon.info avahi-daemon[1157]: Registering new address record for fe80::3c30:52ff:fe26:3562 on eth0.*.
Sat Dec 24 14:22:35 2016 kern.info kernel: [ 819.160000] br-lan: port 1(eth0.1) entered forwarding state
Sat Dec 24 14:22:35 2016 daemon.notice netifd: Network device 'ra0' link is up
Sat Dec 24 14:22:35 2016 kern.info kernel: [ 819.230000] device ra0 entered pro miscuous mode
Sat Dec 24 14:22:35 2016 kern.info kernel: [ 819.240000] br-lan: port 2(ra0) en tered forwarding state
Sat Dec 24 14:22:35 2016 daemon.notice netifd: Interface 'wwan' is enabled
Sat Dec 24 14:22:36 2016 daemon.warn odhcpd[945]: DHCPV6 CONFIRM IA_NA from 0001 00011f69939df0def1bc2580 on br-lan: not on-link
Sat Dec 24 14:22:36 2016 daemon.info dnsmasq-dhcp[1291]: DHCPREQUEST(br-lan) 192 .168.1.146 10:0b:a9:37:ca:30
Sat Dec 24 14:22:36 2016 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168 .1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Sat Dec 24 14:22:36 2016 daemon.warn odhcpd[945]: DHCPV6 SOLICIT IA_NA from 0001 00011f69939df0def1bc2580 on br-lan: ok fd1c:5a88:47dd::753/128
Sat Dec 24 14:22:37 2016 daemon.notice netifd: wan (1543): Sending discover...
Sat Dec 24 14:22:37 2016 kern.info kernel: [ 821.240000] br-lan: port 2(ra0) en tered forwarding state
Sat Dec 24 14:22:37 2016 daemon.warn odhcpd[945]: DHCPV6 REQUEST IA_NA from 0001 00011f69939df0def1bc2580 on br-lan: ok fd1c:5a88:47dd::753/128
Sat Dec 24 14:22:37 2016 daemon.info dnsmasq[1291]: read /etc/hosts - 1 addresse s
Sat Dec 24 14:22:37 2016 daemon.info dnsmasq[1291]: read /tmp/hosts/odhcpd - 1 a ddresses
Sat Dec 24 14:22:37 2016 daemon.info dnsmasq[1291]: read /tmp/hosts/dhcp - 1 add resses
Sat Dec 24 14:22:37 2016 daemon.info dnsmasq-dhcp[1291]: read /etc/ethers - 0 ad dresses
Sat Dec 24 14:22:37 2016 daemon.info dnsmasq-dhcp[1291]: DHCPINFORM(br-lan) 192. 168.1.146 10:0b:a9:37:ca:30
Sat Dec 24 14:22:37 2016 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168 .1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Sat Dec 24 14:22:39 2016 kern.info ap_client: No results
Sat Dec 24 14:22:39 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:22:40 2016 daemon.notice netifd: wan (1543): Sending discover...
Sat Dec 24 14:22:49 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:22:49 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:22:54 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2P SK
Sat Dec 24 14:22:54 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:23:04 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:23:04 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:23:09 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:23:09 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:23:19 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:23:19 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:23:24 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:23:24 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:23:34 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:23:34 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:23:39 2016 kern.info ap_client: No results
Sat Dec 24 14:23:39 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:23:49 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:23:49 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:23:54 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:23:54 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:24:04 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:24:04 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:24:09 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:24:09 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:24:19 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:24:19 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:24:24 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:24:24 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:24:34 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:24:34 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:24:39 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:24:39 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:24:49 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:24:49 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:24:54 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:24:54 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:25:04 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:25:04 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:25:09 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:25:09 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:25:19 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:25:19 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:25:24 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:25:24 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:25:34 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:25:34 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:25:39 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:25:39 2016 kern.info ap_client: Found network - 6 telenet-E04E1 dc:53:7c:9e:04:e6 WPA1PSKWPA2PSK
Sat Dec 24 14:25:39 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:25:45 2016 daemon.info dnsmasq-dhcp[1291]: DHCPINFORM(br-lan) 192.168.1.146 10:0b:a9:37:ca:30
Sat Dec 24 14:25:45 2016 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168.1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Sat Dec 24 14:25:49 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:25:49 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:25:54 2016 kern.info ap_client: No results
Sat Dec 24 14:25:54 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:26:04 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:26:04 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:26:09 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:26:09 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:26:19 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:26:19 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:26:24 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:26:24 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:26:34 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:26:34 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:26:39 2016 kern.info ap_client: No results
Sat Dec 24 14:26:39 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:26:49 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:26:49 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:26:54 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:26:54 2016 kern.info ap_client: Found network - 6 telenet-E04E1 dc:53:7c:9e:04:e6 WPA1PSKWPA2PSK
Sat Dec 24 14:26:54 2016 kern.info ap_client: Found network - 11 WiFi-2.4-AA26 00:37:b7:74:aa:2c WPA2PSK
Sat Dec 24 14:26:54 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:27:04 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:27:04 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:27:09 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:27:09 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:27:19 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:27:19 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:27:24 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:27:24 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:27:34 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:27:34 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:27:39 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:27:39 2016 kern.info ap_client: Found network - 11 WiFi-2.4-AA26 00:37:b7:74:aa:2c WPA2PSK
Sat Dec 24 14:27:39 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:27:49 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:27:49 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:27:54 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:27:54 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:28:04 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:28:04 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:28:09 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:28:09 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:28:19 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:28:19 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:28:24 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:28:24 2016 kern.info ap_client: Found network - 11 WiFi-2.4-AA26 00:37:b7:74:aa:2c WPA2PSK
Sat Dec 24 14:28:24 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:28:34 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:28:34 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:28:39 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:28:39 2016 kern.info ap_client: Found network - 11 WiFi-2.4-AA26 00:37:b7:74:aa:2c WPA2PSK
Sat Dec 24 14:28:39 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:28:49 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:28:49 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:28:54 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:28:54 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:29:04 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:29:04 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:29:09 2016 kern.info ap_client: Found network - 11 WiFi-2.4-AA26 00:37:b7:74:aa:2c WPA2PSK
Sat Dec 24 14:29:09 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:29:19 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:29:19 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:29:24 2016 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Sat Dec 24 14:29:24 2016 kern.info ap_client: No signal found to connect to
Sat Dec 24 14:29:34 2016 kern.info ap_client: apcli0 is not associated
Sat Dec 24 14:29:34 2016 kern.info ap_client: Scanning for networks...
Sat Dec 24 14:29:35 2016 daemon.notice netifd: Interface 'wwan' is disabled
and
root@OpenWrt:/# wifi
root@OpenWrt:/# [ 1310.310000] br-lan: port 2(ra0) entered disabled state
[ 1310.330000] device ra0 left promiscuous mode
[ 1310.330000] br-lan: port 2(ra0) entered disabled state
[ 1310.690000] efuse_probe: efuse = 10000002
[ 1310.860000] tssi_0_target_pwr_g_band = 35
[ 1310.860000] tssi_1_target_pwr_g_band = 35
[ 1316.110000] <==== rt28xx_init, Status=0
[ 1316.240000] device ra0 entered promiscuous mode
[ 1316.240000] br-lan: port 2(ra0) entered forwarding state
[ 1316.250000] br-lan: port 2(ra0) entered forwarding state
[ 1318.250000] br-lan: port 2(ra0) entered forwarding state
my network is telenet-apn
Posted: Sun Jan 08, 2017 9:18 pm
by kosmonaut pirx
for "try your setup" I just use "wifi" command
according to the log, you've at max three wifi's in range:
telenet-apn-D4F49
telenet-E04E1
WiFi-2.4-AA26
but according to this
you don't want to connect to any of them.
This message I receive in case I use an unknown ssid.
Therefore, please check the ssid given, either in comamnd used
of in
/etc/config/wireless.
name have to match.
Posted: Mon Jan 09, 2017 8:43 pm
by herci
I did all the commands from the first post again and I just copied the name of my wifi, to assure I made no mistakes in the following line
uci set wireless.sta.ssid=[telenet-apn-D4F49]
you talk about a etc/config/wireless command, but there isn't a command like this in the tutorial, did I forget something?
Then I connected through serial again, because when I ssh and type wifi I disconnect.
And typed in serial connection: 'wifi' and I get this:
root@OpenWrt:/# [ 538.620000] br-lan: port 2(ra0) entered disabled state
[ 538.660000] device ra0 left promiscuous mode
[ 538.660000] br-lan: port 2(ra0) entered disabled state
[ 539.020000] efuse_probe: efuse = 10000002
[ 539.180000] tssi_0_target_pwr_g_band = 35
[ 539.190000] tssi_1_target_pwr_g_band = 35
[ 544.450000] <==== rt28xx_init, Status=0
[ 544.580000] device ra0 entered promiscuous mode
[ 544.580000] br-lan: port 2(ra0) entered forwarding state
[ 544.590000] br-lan: port 2(ra0) entered forwarding state
[ 546.590000] br-lan: port 2(ra0) entered forwarding state
I also did a reboot and got this:
Image Name: MIPS OpenWrt Linux-3.18.29
Data Size: 1146194 Bytes = 1.1 MB
Load Address: 80000000
Entry Point: 80000000
Verifying Checksum ... OK
No initrd
Starting kernel ...
[ 0.000000] Linux version 3.18.29 (vocore@ubuntu) (gcc version 4.8.3 (OpenWrt /Linaro GCC 4.8-2014.04 r49378) ) #32 Sat Dec 24 22:01:05 CST 2016
[ 0.000000] Board has DDR2
[ 0.000000] Zone ranges:
[ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 byt es
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 32512
[ 0.000000] Kernel command line: console=ttyS2,115200 rootfstype=squashfs,jff s2
[ 0.000000] Writing ErrCtl register=0001d14c
[ 0.000000] Readback ErrCtl register=0001d14c
[ 0.000000] Memory: 126340K/131072K available (2530K kernel code, 131K rwdata , 520K rodata, 136K init, 186K bss, 4732K reserved)
[ 0.000000] NR_IRQS:256
[ 0.000000] CPU Clock: 580MHz
[ 0.190000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORIT Y) (c) 2001-2006 Red Hat, Inc.
[ 0.230000] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[ 0.240000] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2 500000) is a 16550A
[ 0.250000] console [ttyS2] disabled
[ 0.260000] 10000e00.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2 500000) is a 16550A
[ 0.270000] console [ttyS2] enabled
[ 0.270000] bootconsole [early0] disabled
[ 0.280000] spi-mt7621 10000b00.spi: sys_freq: 193333333
[ 0.290000] m25p80 spi32766.0: found gd25q128, expected en25q64
[ 0.300000] m25p80 spi32766.0: gd25q128 (16384 Kbytes)
[ 0.300000] m25p80 spi32766.0: using chunked io
[ 0.310000] 4 ofpart partitions found on MTD device spi32766.0
[ 0.320000] Creating 4 MTD partitions on "spi32766.0":
[ 0.320000] 0x000000000000-0x000000030000 : "u-boot"
[ 0.330000] 0x000000030000-0x000000040000 : "u-boot-env"
[ 0.330000] 0x000000040000-0x000000050000 : "factory"
[ 0.340000] 0x000000050000-0x000001000000 : "firmware"
[ 0.410000] 2 uimage-fw partitions found on MTD device firmware
[ 0.410000] 0x000000050000-0x000000167d92 : "kernel"
[ 0.420000] 0x000000167d92-0x000001000000 : "rootfs"
[ 0.420000] mtd: device 5 (rootfs) set to be root filesystem
[ 0.430000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.440000] 0x0000006f0000-0x000001000000 : "rootfs_data"
[ 0.450000] ralink_soc_eth 10100000.ethernet: generated random MAC address ae :79:59:21:8a:b2
[ 0.460000] ralink_soc_eth 10100000.ethernet eth0: ralink at 0xb0100000, irq 5
[ 0.470000] mt7621_wdt 10000120.watchdog: Initialized
[ 0.480000] TCP: cubic registered
[ 0.480000] NET: Registered protocol family 17
[ 0.480000] bridge: automatic filtering via arp/ip/ip6tables has been depreca ted. Update your scripts to load br_netfilter if you need this.
[ 0.500000] 8021q: 802.1Q VLAN Support v1.8
[ 0.520000] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 0.520000] Freeing unused kernel memory: 136K (8031e000 - 80340000)
[ 2.320000] init: Console is alive
[ 2.320000] init: - watchdog -
[ 5.860000] usbcore: registered new interface driver usbfs
[ 5.860000] usbcore: registered new interface driver hub
[ 5.870000] usbcore: registered new device driver usb
[ 5.880000] exFAT: Version 1.2.9
[ 5.930000] SCSI subsystem initialized
[ 5.940000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.950000] ehci-platform: EHCI generic platform driver
[ 5.970000] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[ 5.970000] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[ 5.980000] ehci-platform 101c0000.ehci: EHCI Host Controller
[ 5.980000] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[ 5.990000] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[ 6.020000] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[ 6.020000] hub 1-0:1.0: USB hub found
[ 6.030000] hub 1-0:1.0: 1 port detected
[ 6.030000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 6.040000] ohci-platform: OHCI generic platform driver
[ 6.050000] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[ 6.050000] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[ 6.060000] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[ 6.130000] hub 2-0:1.0: USB hub found
[ 6.130000] hub 2-0:1.0: 1 port detected
[ 6.150000] MTK MSDC device init.
[ 6.190000] mtk-sd: MediaTek MT6575 MSDC Driver
[ 6.190000] sdhci: Secure Digital Host Controller Interface driver
[ 6.200000] sdhci: Copyright(c) Pierre Ossman
[ 6.210000] sdhci-pltfm: SDHCI platform and OF driver helper
[ 6.220000] usbcore: registered new interface driver usb-storage
[ 6.450000] init: - preinit -
[ 7.600000] rt305x-esw 10110000.esw: link changed 0x00
[ 7.800000] random: mktemp urandom read with 13 bits of entropy available
[ 11.060000] mount_root: loading kmods from internal overlay
[ 11.760000] jffs2: notice: (375) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 11.780000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[ 11.840000] block: extroot: not configured
[ 12.040000] jffs2: notice: (372) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 12.060000] mount_root: loading kmods from internal overlay
[ 12.580000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[ 12.630000] block: extroot: not configured
[ 12.630000] mount_root: switching to jffs2 overlay
[ 12.660000] procd: - early -
[ 12.660000] procd: - watchdog -
[ 13.470000] procd: - ubus -
[ 14.500000] procd: - init -
[ 15.930000] NET: Registered protocol family 10
[ 15.990000] ntfs: driver 2.1.31 [Flags: R/O MODULE].
[ 16.050000] tun: Universal TUN/TAP device driver, 1.6
[ 16.050000] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 16.070000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 16.080000] i2c /dev entries driver
[ 16.990000] <-- RTMPAllocTxRxRingMemory, Status=0, ErrorValue=0x
[ 16.990000] <-- RTMPAllocAdapterBlock, Status=0
[ 17.030000] i2c-gpio i2c-gpio: using pins 5 (SDA) and 4 (SCL)
[ 17.050000] Linux video capture interface: v2.00
[ 17.090000] mt7628-i2s 10000a00.i2s: loaded, sys freq is 480MHz.
[ 17.100000] es8388_codec_probe
[ 17.100000] set system reference clock(mclk) to 12MHz.
[ 17.110000] mt7628-audio audio-card: es8388-hifi <-> 10000a00.i2s mapping ok
[ 17.130000] mt7628-audio audio-card: load
[ 17.150000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 17.170000] nf_conntrack version 0.5.0 (1976 buckets, 7904 max)
[ 17.250000] usbcore: registered new interface driver usblp
[ 17.280000] usbcore: registered new interface driver uvcvideo
[ 17.290000] USB Video Class driver (1.1.1)
[ 17.310000] xt_time: kernel timezone is -0000
[ 17.320000] PPP generic driver version 2.4.2
[ 17.330000] NET: Registered protocol family 24
[ 24.350000] device eth0.1 entered promiscuous mode
[ 24.360000] device eth0 entered promiscuous mode
[ 24.390000] br-lan: port 1(eth0.1) entered forwarding state
[ 25.860000] efuse_probe: efuse = 10000002
[ 26.090000] tssi_0_target_pwr_g_band = 35
[ 26.090000] tssi_1_target_pwr_g_band = 35
[ 26.390000] br-lan: port 1(eth0.1) entered forwarding state
[ 33.030000] <==== rt28xx_init, Status=0
[ 33.930000] device ra0 entered promiscuous mode
[ 33.940000] br-lan: port 2(ra0) entered forwarding state
[ 35.940000] br-lan: port 2(ra0) entered forwarding state
[ 58.560000] random: nonblocking pool is initialized
Posted: Mon Jan 09, 2017 8:58 pm
by herci
maybe this is useful too, I'm trying all sorts of stuff I found on google
without vi it was permission denied
root@OpenWrt:/# vi /etc/config/network
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd1c:5a88:47dd::/48'
config interface 'lan'
option ifname 'eth0.1'
option force_link '1'
option macaddr 'b8:d8:12:67:13:e0'
option type 'bridge'
option ipaddr '192.168.1.1'
option netmask '255.255.255.0'
option ip6assign '60'
config interface 'wan'
option ifname 'eth0.2'
option macaddr 'b8:d8:12:67:13:e1'
option proto 'dhcp'
config interface 'wan6'
option proto 'dhcpv6'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option ports '1 2 3 4 6t'
config switch_vlan
option vlan '2'
- /etc/config/network 32/48 66%
Posted: Mon Jan 09, 2017 9:45 pm
by cory
your network doesn't have what mentions in step 5. of Setup AP + STA Mode section
http://vocore.io/v2u.html
Posted: Mon Jan 09, 2017 9:58 pm
by herci
you're right,
did it again now
got this:
root@OpenWrt:/# uci set wireless.sta.ssid=[telenet-apn-D4F49]
et wireless.sta.key=[my password here]
uci sroot@OpenWrt:/#
root@OpenWrt:/# uci set wireless.sta.key=[this contains my password]
uci commit
sleep 1root@OpenWrt:/#
root@OpenWrt:/# uci set wireless.sta.network=wwan
0
uci commit
uci set nroot@OpenWrt:/#
root@OpenWrt:/# uci set wireless.sta.disabled=0
uci commit
uci del_list root@OpenWrt:/#
root@OpenWrt:/# uci commit
uci commit
uci commit
/etc/init.d/network restartroot@OpenWrt:/#
root@OpenWrt:/# /etc/init.d/network restart
[ 368.970000] br-lan: port 2(ra0) entered disabled state
[ 368.980000] br-lan: port 1(eth0.1) entered disabled state
[ 369.000000] device eth0.1 left promiscuous mode
[ 369.000000] br-lan: port 1(eth0.1) entered disabled state
[ 369.010000] IPv6: ADDRCONF(NETDEV_UP): eth0.1: link is not ready
[ 369.020000] device ra0 left promiscuous mode
[ 369.020000] br-lan: port 2(ra0) entered disabled state
[ 369.270000] device eth0 left promiscuous mode
root@OpenWrt:/# sleep 10
[ 371.090000] device eth0.1 entered promiscuous mode
[ 371.090000] device eth0 entered promiscuous mode
[ 371.110000] br-lan: port 1(eth0.1) entered forwarding state
[ 373.110000] br-lan: port 1(eth0.1) entered forwarding state
[ 373.180000] device ra0 entered promiscuous mode
[ 373.180000] br-lan: port 2(ra0) entered forwarding state
[ 373.190000] br-lan: port 2(ra0) entered forwarding state
[ 375.190000] br-lan: port 2(ra0) entered forwarding state
root@OpenWrt:/#
root@OpenWrt:/# uci set wireless.sta.disabled=1
root@OpenWrt:/#
root@OpenWrt:/#
root@OpenWrt:/# uci delete network.wwan
root@OpenWrt:/#
root@OpenWrt:/# uci set network.wwan=interface
root@OpenWrt:/#
root@OpenWrt:/# uci set network.wwan.proto=dhcp
root@OpenWrt:/#
root@OpenWrt:/#
root@OpenWrt:/# uci del_list firewall.@zone[1].network=wwan
root@OpenWrt:/#
root@OpenWrt:/# uci add_list firewall.@zone[1].network=wwan
root@OpenWrt:/#
root@OpenWrt:/# uci set firewall.@zone[1].input=ACCEPT
root@OpenWrt:/#
root@OpenWrt:/# uci set firewall.@zone[1].output=ACCEPT
root@OpenWrt:/#
root@OpenWrt:/# uci set firewall.@zone[1].forward=ACCEPT
root@OpenWrt:/#
root@OpenWrt:/# uci set firewall.@zone[1].masq=1
root@OpenWrt:/#
root@OpenWrt:/# uci set firewall.@zone[1].mtu_fix=1
root@OpenWrt:/#
root@OpenWrt:/#
root@OpenWrt:/#
root@OpenWrt:/#
root@OpenWrt:/#
root@OpenWrt:/#
[ 387.240000] br-lan: port 2(ra0) entered disabled state
[ 387.250000] br-lan: port 1(eth0.1) entered disabled state
[ 387.270000] device eth0.1 left promiscuous mode
[ 387.270000] br-lan: port 1(eth0.1) entered disabled state
[ 387.280000] IPv6: ADDRCONF(NETDEV_UP): eth0.1: link is not ready
[ 387.300000] device ra0 left promiscuous mode
[ 387.300000] br-lan: port 2(ra0) entered disabled state
[ 387.550000] device eth0 left promiscuous mode
root@OpenWrt:/# [ 389.310000] device eth0.1 entered promiscuous mode
[ 389.320000] device eth0 entered promiscuous mode
[ 389.330000] br-lan: port 1(eth0.1) entered forwarding state
[ 390.190000] device ra0 entered promiscuous mode
[ 390.200000] br-lan: port 2(ra0) entered forwarding state
[ 391.330000] br-lan: port 1(eth0.1) entered forwarding state
[ 392.200000] br-lan: port 2(ra0) entered forwarding state
wifi
root@OpenWrt:/# [ 398.630000] ERROR!!! RTMPSetTimer failed, Halt in Progress!
[ 398.650000] br-lan: port 2(ra0) entered disabled state
[ 398.660000] device ra0 left promiscuous mode
[ 398.670000] br-lan: port 2(ra0) entered disabled state
[ 399.040000] efuse_probe: efuse = 10000002
[ 399.210000] tssi_0_target_pwr_g_band = 35
[ 399.210000] tssi_1_target_pwr_g_band = 35
[ 404.200000] <==== rt28xx_init, Status=0
[ 404.340000] device ra0 entered promiscuous mode
[ 404.340000] br-lan: port 2(ra0) entered forwarding state
[ 404.350000] br-lan: port 2(ra0) entered forwarding state
[ 406.350000] br-lan: port 2(ra0) entered forwarding state
Posted: Mon Jan 09, 2017 10:09 pm
by kosmonaut pirx
herci wrote:I did all the commands from the first post again and I just copied the name of my wifi, to assure I made no mistakes in the following line
Ok, sorry, some wrong assumptions here.
First,
'/etc/config/wireless' is a config file at the flash drive, No command. As you already found out, you may edit it with e.g. 'vi' command or view it with 'less' command or 'more' command or 'cat' or maybe some other programs installed already. Those are some linux "default" programs, btw, you'll find them at almost any installed unix-like systems.
This config file describes your wifi config. Take a look at it.
Second,
the uci command you use should be
uci set wireless.sta.ssid='telenet-apn-D4F49'
or
uci set wireless.sta.ssid="telenet-apn-D4F49"
in case you have no special chars in the ssid (is this valid? don't know)
Absolutely NO square brackets at all! This might be intentional for some, but maybe an additional note in the wiki might help others.
Now that you can view the config file, you can see after an 'uci commit' how the configuration changes.
and Third, finally,
you can use the 'wifi' command to restart the wifi services. Unfortunately, someone put a "disabled" in the default '/etc/rc.local' file (exercise: take a look at it using e.g. 'cat' ) after 10seconds. You'll note that your STA interface in '/etc/config/wireless' always is set to disabled after some time (line: option disabled '1'). Took some time to find that and very annoying
So in order to use 'wifi' command you may a) re-enable it (via uci or edit config file) or comment all stuff in /etc/rc.local' out. I did the latter.
If you don't do this, 'wifi' command does nothing with your STA resp. wifi access, as it is/was disabled. You've seen this already, don't you.
regards.
Posted: Mon Jan 09, 2017 10:12 pm
by cory
can you type cat /etc/config/network and post the result
