Error: sd-card ejects with read failures
Posted: Wed Jan 11, 2017 2:33 pm
I tried to attach sd-cards to my Vocore2 Ultimate (firmware 2016.12.24) and got some strange behavior. After plugging in the sd-card, I get a sequence of repeating messages in dmesg saying that the sd-card is removed and re-attached due to read failures. I tried two different sd-cards (SanDisk Ultra 8 GB SDHC and 32 GB SDHC), with different partitions (one or two partitions on it, formatted with either VFAT or EXT4), and all of them are read properly in different other setups (in an sd-card-reader or in a Beaglebone board).
Following are two examples of the never-ending sequence of error messages:
Can anybody help to get the sd-cards working?
[ 279.580000] mmc0: new high speed SDHC card at address e624
[ 279.580000] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[ 279.600000] mmcblk0: p1 p2
[ 281.670000] msdc-1 -> cmd<18> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x6ad>
[ 281.680000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x6ad>
[ 281.690000] mmcblk0: error -159 sending status command, retrying
[ 281.700000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x6ad>
[ 281.710000] mmcblk0: error -159 sending status command, retrying
[ 281.710000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x6ad>
[ 281.720000] mmcblk0: error -159 sending status command, aborting
[ 281.730000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x6ad>
[ 281.740000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x6ad>
[ 281.750000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x6ad>
[ 281.760000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x6ad>
[ 281.770000] mmc0: card e624 removed
[ 282.930000] mmc0: new high speed SDHC card at address e624
[ 282.930000] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[ 282.950000] mmcblk0: p1 p2
[ 285.370000] FAT-fs (mmcblk0p1): Directory bread(block 2256) failed
[ 285.380000] EXT4-fs warning (device mmcblk0p2): __ext4_read_dirblock:884: error -5 reading directory block (ino)
[ 286.420000] FAT-fs (mmcblk0p1): Directory bread(block 2256) failed
[ 286.430000] EXT4-fs warning (device mmcblk0p2): __ext4_read_dirblock:884: error -5 reading directory block (ino)
[ 287.470000] FAT-fs (mmcblk0p1): Directory bread(block 2256) failed
[ 287.480000] EXT4-fs warning (device mmcblk0p2): __ext4_read_dirblock:884: error -5 reading directory block (ino)
[ 288.010000] msdc-1 -> cmd<18> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x6c9>
[ 288.020000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x6c9>
[ 288.030000] mmcblk0: error -159 sending status command, retrying
[ 288.030000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x6c9>
[ 288.040000] mmcblk0: error -159 sending status command, retrying
[ 288.050000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x6c9>
[ 288.060000] mmcblk0: error -159 sending status command, aborting
[ 288.060000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x6c9>
[ 288.070000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x6c9>
[ 288.080000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x6c9>
[ 288.090000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x6c9>
[ 288.100000] mmc0: card e624 removed
[ 289.240000] mmc0: new high speed SDHC card at address e624
[ 289.260000] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[ 289.260000] mmcblk0: p1 p2
[ 293.250000] FAT-fs (mmcblk0p1): Directory bread(block 2256) failed
[ 293.250000] EXT4-fs warning (device mmcblk0p2): __ext4_read_dirblock:884: error -5 reading directory block (ino)
[ 293.470000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<kworker/u2:1><0x8>
[ 293.480000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<kworker/u2:1><0x8>
[ 293.490000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<kworker/u2:1><0x8>
[ 293.500000] mmc0: card e624 removed
[ 294.300000] FAT-fs (mmcblk0p1): Directory bread(block 2256) failed
[ 294.300000] EXT4-fs warning (device mmcblk0p2): __ext4_read_dirblock:884: error -5 reading directory block (ino)
[ 294.630000] mmc0: new high speed SDHC card at address e624
[ 294.630000] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[ 294.640000] mmcblk0: p1 p2
[ 295.350000] FAT-fs (mmcblk0p1): Directory bread(block 2256) failed
[ 295.350000] EXT4-fs warning (device mmcblk0p2): __ext4_read_dirblock:884: error -5 reading directory block (ino)
[ 295.870000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<kworker/u2:1><0x8>
[ 295.880000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<kworker/u2:1><0x8>
[ 295.890000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<kworker/u2:1><0x8>
[ 295.900000] mmc0: card e624 removed
[ 297.070000] mmc0: new high speed SDHC card at address e624
[ 297.070000] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[ 297.100000] mmcblk0: p1 p2
[ 118.760000] mmcblk0: mmc0:0007 SL32G 28.9 GiB
[ 118.770000] mmcblk0: p1
[ 119.530000] EXT4-fs (mmcblk0p1): recovery complete
[ 119.550000] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts:
[ 120.970000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<kworker/u2:1><0x8>
[ 120.980000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<kworker/u2:1><0x8>
[ 120.990000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<kworker/u2:1><0x8>
[ 121.000000] mmc0: card 0007 removed
[ 122.100000] mmc0: new high speed SDHC card at address 0007
[ 122.110000] mmcblk0: mmc0:0007 SL32G 28.9 GiB
[ 122.120000] mmcblk0: p1
[ 123.160000] EXT4-fs warning (device mmcblk0p1): __ext4_read_dirblock:884: error -5 reading directory block (ino)
[ 124.200000] EXT4-fs warning (device mmcblk0p1): __ext4_read_dirblock:884: error -5 reading directory block (ino)
[ 126.260000] msdc-1 -> cmd<18> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x66b>
[ 126.270000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x66b>
[ 126.280000] mmcblk0: error -159 sending status command, retrying
[ 126.290000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x66b>
[ 126.300000] mmcblk0: error -159 sending status command, retrying
[ 126.300000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x66b>
[ 126.310000] mmcblk0: error -159 sending status command, aborting
[ 126.320000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x66b>
[ 126.330000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x66b>
[ 126.340000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<mmcqd/0><0x66b>
[ 126.350000] mmc0: card 0007 removed
[ 127.440000] mmc0: new high speed SDHC card at address 0007
[ 127.450000] mmcblk0: mmc0:0007 SL32G 28.9 GiB
[ 127.460000] mmcblk0: p1
[ 128.060000] JBD2: Error -5 detected when updating journal superblock for mmcblk0p1-8.
[ 128.060000] Aborting journal on device mmcblk0p1-8.
[ 128.070000] JBD2: Error -5 detected when updating journal superblock for mmcblk0p1-8.
[ 128.400000] EXT4-fs warning (device mmcblk0p1): __ext4_read_dirblock:884: error -5 reading directory block (ino)
[ 129.440000] EXT4-fs warning (device mmcblk0p1): __ext4_read_dirblock:884: error -5 reading directory block (ino)
[ 130.660000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<kworker/u2:1><0x8>
[ 130.670000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<kworker/u2:1><0x8>
[ 130.680000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<kworker/u2:1><0x8>
[ 130.690000] mmc0: card 0007 removed
[ 132.770000] mmc0: new high speed SDHC card at address 0007
[ 132.780000] mmcblk0: mmc0:0007 SL32G 28.9 GiB
[ 132.790000] mmcblk0: p1
[ 133.530000] EXT4-fs warning (device mmcblk0p1): __ext4_read_dirblock:884: error -5 reading directory block (ino)
[ 134.570000] EXT4-fs warning (device mmcblk0p1): __ext4_read_dirblock:884: error -5 reading directory block (ino)
[ 134.990000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<kworker/u2:3><0x656>
[ 135.000000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<kworker/u2:3><0x656>
[ 135.010000] msdc-1 -> cmd<13> card<0> power<2> <- msdc_ops_request() : L<2120> PID<kworker/u2:3><0x656>
[ 135.020000] mmc0: card 0007 removed
[ 136.130000] mmc0: new high speed SDHC card at address 0007
[ 136.140000] mmcblk0: mmc0:0007 SL32G 28.9 GiB
[ 136.150000] mmcblk0: p1
