Default Config VoCore2 Ultimate
Posted: Thu Jan 12, 2017 9:26 pm
by betabrain
Where can I find the default / factory configuration for the VoCore2 Ultimate? I managed to mess up its wifi config within minutes of first use (config change via graphical interface). And unfortunately the instructions on the STA+AP page don't help:
root@OpenWrt:/# uci set wireless.sta.ssid=[HOMEWIFI]
uci: Invalid argument
root@OpenWrt:/# uci set wireless.sta.ssid='HOMEWIFI'
root@OpenWrt:/# uci set wireless.sta.ssid=HOMEWIFI
Re: Default Config VoCore2 Ultimate
Posted: Fri Jan 13, 2017 2:06 pm
[HOMEWIFI] this means replace with your home router wireless hotspot name.
please paste three config here: /etc/config/wireless, /etc/config/firmware, /etc/config/network
Posted: Mon Jan 16, 2017 11:11 am
by betabrain
/etc/config/wireless- Code: Select all
config wifi-device 'radio0'
option type 'ralink'
option variant 'mt7628'
option country 'CH'
config wifi-iface
option device 'radio0'
option network 'wifi'
option mode 'ap'
option ssid 'VoCore'
option encryption 'psk2'
option key 'superman12345'
/etc/config/firmware- Code: Select all
config defaults
option syn_flood '1'
option input 'ACCEPT'
option output 'ACCEPT'
option forward 'REJECT'
config zone
option name 'lan'
option forward 'ACCEPT'
option network 'lan'
config zone
option name 'wan'
option input 'REJECT'
option masq '1'
option mtu_fix '1'
option network 'wan wan6 wwan'
config forwarding
option src 'lan'
option dest 'wan'
config rule
option name 'Allow-DHCP-Renew'
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'
config rule
option name 'Allow-Ping'
option src 'wan'
option proto 'icmp'
option icmp_type 'echo-request'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option src_ip 'fe80::/10'
option src_port '547'
option dest_ip 'fe80::/10'
option dest_port '546'
option family 'ipv6'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
config rule
option name 'Allow-ICMPv6-Input'
option src 'wan'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
list icmp_type 'destination-unreachable'
list icmp_type 'packet-too-big'
list icmp_type 'time-exceeded'
list icmp_type 'bad-header'
list icmp_type 'unknown-header-type'
list icmp_type 'router-solicitation'
list icmp_type 'neighbour-solicitation'
list icmp_type 'router-advertisement'
list icmp_type 'neighbour-advertisement'
option limit '1000/sec'
config rule
option name 'Allow-ICMPv6-Forward'
option src 'wan'
option dest '*'
option proto 'icmp'
config include
option path '/etc/firewall.user'
config rule
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
/etc/config/network- Code: Select all
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd47:f447:6340::/48'
config interface 'lan'
option ifname 'eth0.1'
option force_link '1'
option macaddr '00:0c:43:e1:76:28'
option type 'bridge'
option ipaddr '192.168.1.1'
option ip6assign '60'
config interface 'wan'
option ifname 'eth0.2'
option macaddr '00:0c:43:e1:76:29'
option proto 'dhcp'
config interface 'wan6'
option proto 'dhcpv6'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option ports '1 2 3 4 6t'
config switch_vlan
option vlan '2'
option ports '0 6t'
config interface 'wwan'
option proto 'dhcp'
config interface 'wifi'
option ipaddr '192.168.2.1'
Posted: Tue Jan 17, 2017 12:41 am
Looks like it is normal, try firstboot -y and reboot your vocore, make the config back to default. check if it works.
Posted: Tue Jan 17, 2017 12:16 pm
by betabrain
Thanks. The default config works.
What is the recommended next step? Is there a firmware update I should do?
Posted: Thu Jan 26, 2017 5:10 pm
by freaky2xd
hey I am a noob considering programming and stuff!
how exactly can I restore the vocore2+dock?
I messed up the settings and now there is no ap but the lights are both on...
I only know how to access the vocore via putty in order to get to the openwrt interface and then my knowledge is gone
Posted: Fri Jan 27, 2017 2:24 pm
freaky2xd wrote:hey I am a noob considering programming and stuff!
First, connect your vocore to your computer, then install usb2ttl driver on vocore.io/v2, finally login to console by TTL and run firstboot -y
