How to connect via ethernet?
Posted: Fri Jan 27, 2017 3:45 pm
by der.schultze
today I start testing my new VoCore2 Ultimate. I can connect via wifi and I can see, that the vocore got an IP from my router for the ethernet port.
If I ping the vocore, I get answers, but I cannot connect to it over ehternet. Wether with ssh nor http.
I want to use it as an AP in my existing network.
What I have to do?
Thanks,
Schultze
Re: How to connect via ethernet?
Posted: Sun Jan 29, 2017 1:14 am
check vocore.io/v2 setup ap+sta mode. you only need sta mode.
Posted: Sun Jan 29, 2017 3:10 pm
by der.schultze
Vonger wrote:check vocore.io/v2 setup ap+sta mode. you only need sta mode.
Still no access via ethernet. Now also no ssh access via wifi.
What is sta mode? I don't know this.
Schultze
Posted: Mon Jan 30, 2017 12:11 pm
can you directly connect vocore2 and your computer with wires?
connect to your vocore2 by USB2TTL, check what is happening.
check vocore.io/v2: "Connect to VoCore2 Console through its MicroUSB Port"
Posted: Thu Feb 02, 2017 4:45 pm
by der.schultze
Vonger wrote:can you directly connect vocore2 and your computer with wires?
Sure, I have done all these via USB2TTL.
Schultze
Posted: Fri Feb 03, 2017 1:54 am
Good
Now you can follow vocore.io/v2, AP+STA tutorial,
PS: last tutorial missed quote. when you using uci, do not forget add quote surround the value.
