VoCore2 Firmware: Compile from Source
Posted: Fri Feb 03, 2017 7:17 am
by Eyal
I followed the instructions provided here http://vonger.cn/?p=4400. I was unable to register there (never received the confirmation email).
As usual I had to apply three patches to allow the build to move on. However, the build then failed here:
OpenWrt-libtool: link:  mipsel-openwrt-linux-uclibc-gcc -shared  -fPIC -DPIC  ptp2/.libs/ptp2_la-ptp.o ptp2/.libs/ptp2_la-library.o ptp2/.libs/ptp2_la-usb.o ptp2/.libs/ptp2_la-ptpip.o ptp2/.libs/ptp2_la-config.o ptp2/.libs/ptp2_la-olympus-wrap.o ptp2/.libs/ptp2_la-chdk.o   -Wl,-rpath -Wl,/data/vocore/openwrt/build_dir/target-mipsel_24kec+dsp_uClibc-0.9.33.2/libgphoto2-2.5.10/libgphoto2/.libs -Wl,-rpath -Wl,/data/vocore/openwrt/build_dir/target-mipsel_24kec+dsp_uClibc-0.9.33.2/libgphoto2-2.5.10/libgphoto2_port/libgphoto2_port/.libs -L/data/vocore/openwrt/build_dir/target-mipsel_24kec+dsp_uClibc-0.9.33.2/libgphoto2-2.5.10/libgphoto2_port/libgphoto2_port/.libs -L/data/vocore/openwrt/staging_dir/target-mipsel_24kec+dsp_uClibc-0.9.33.2/usr/lib -L/data/vocore/openwrt/staging_dir/target-mipsel_24kec+dsp_uClibc-0.9.33.2/lib -L/data/vocore/openwrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_uClibc-0.9.33.2/usr/lib -L/data/vocore/openwrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_uClibc-0.9.33.2/lib -L/data/vocore/openwrt/staging_dir/target-mipsel_24kec+dsp_uClibc-0.9.33.2/usr/lib/libiconv-stub/lib -L/data/vocore/openwrt/staging_dir/target-mipsel_24kec+dsp_uClibc-0.9.33.2/usr/lib/libintl-stub/lib ../libgphoto2/.libs/libgphoto2.so /data/vocore/openwrt/build_dir/target-mipsel_24kec+dsp_uClibc-0.9.33.2/libgphoto2-2.5.10/libgphoto2_port/libgphoto2_port/.libs/libgphoto2_port.so -lexif ../libgphoto2_port/libgphoto2_port/.libs/libgphoto2_port.so -lpthread -lxml2 -lz -lm -ldl -lltdl  -Os -mno-branch-likely -mips32r2 -mtune=24kec -mdsp -msoft-float -Os -mno-branch-likely -mips32r2 -mtune=24kec -mdsp -msoft-float   -Wl,-soname -Wl,ptp2.so -Wl,-version-script -Wl,.libs/ptp2.ver -o .libs/ptp2.so
/data/vocore/openwrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_uClibc-0.9.33.2/bin/../lib/gcc/mipsel-openwrt-linux-uclibc/4.8.3/../../../../mipsel-openwrt-linux-uclibc/bin/ld: cannot find -lxml2
Re: VoCore2 Firmware: Compile from Source
Posted: Fri Feb 03, 2017 7:24 am
We have uploaded source to http://vocore.io/v2u.html Sources/Software section, please use that code.
Posted: Fri Feb 03, 2017 10:24 am
by Eyal
[later] I modified the top .config and enabled
CONFIG_PACKAGE_libxml2=y
The build now completed.
Posted: Fri Feb 03, 2017 12:52 pm
by Eyal
The uploaded file is identical to the one in the original site.
Are you sure that you can build from that tar file with no problems?
I found that I need to do what is mentioned here (3 patches)
https://dev.openwrt.org/ticket/22193
and also select in .config
Maybe some of the problems are due to the newer compiler in recent fedora which are more strict, but surely the missing libxml2 is not related?
Anyway, thanks for your effort,
cheers
