Powering VoCore2+dock over micro USB + plugged micro SD card
Posted: Thu Mar 09, 2017 2:35 am
Yeah here is the problem.
When micro SD card is plugged gap between edge of the card and side of metal tip of micro USB plug is only a little more than 1 mm.
Typical micro USB cable plug is to thick to have both plugged.
Someone found maybe solution for this issue?
I've started looking for kind of cable with angle plug or cable with slim plug but so far did not found anything usefull
