No success in connecting as client to WLAN AP
Posted: Wed Feb 07, 2018 9:28 am
				According to the information in the blog I tried to connect the vocore2 as a WLAN client as follows:
/etc/config/network:
After doing a manual "insmod mt7628.ko" which works fine, I trigger this script with WLAN credentials fitting to my setup (my AP is operating on channel 6):
Now "ifconfig" tells me this:
Any idea, why the vocore does not establish a WLAN connection and does not get an IP via DHCP?
- config interface 'loopback'
 option ifname 'lo'
 option proto 'static'
 option ipaddr '127.0.0.1'
 option netmask '255.0.0.0'
 config interface 'br-lan'
 option ifname 'eth0'
 option type 'bridge'
 option _orig_ifname 'eth0 ra0 wlan0'
 option _orig_bridge 'true'
 option proto 'dhcp'
 option hostname 'vocore'
 config interface 'wlan'
 option ifname 'ra0'
 option _orig_ifname 'eth0 ra0 br-lan'
 option proto 'dhcp'
- #!/bin/sh
 /root/iwpriv ra0 set Channel=6
 /root/iwpriv apcli0 set ApCliEnable=0
 /root/iwpriv apcli0 set ApCliAuthMode=WPA2PSK
 /root/iwpriv apcli0 set ApCliEncrypType=AES
 /root/iwpriv apcli0 set ApCliSsid=myssid
 /root/iwpriv apcli0 set ApCliWPAPSK=mypassword
 /root/iwpriv apcli0 set ApCliEnable=1
- br-loopback Link encap:Ethernet HWaddr B8:D8:12:67:0F:2E
 inet6 addr: fe80::bad8:12ff:fe67:f2e/64 Scope:Link
 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
 TX packets:13 errors:0 dropped:0 overruns:0 carrier:0
 collisions:0 txqueuelen:1000
 RX bytes:0 (0.0 B) TX bytes:2326 (2.2 KiB)
 br-wlan Link encap:Ethernet HWaddr B8:D8:12:67:0F:2D
 inet6 addr: fe80::bad8:12ff:fe67:f2d/64 Scope:Link
 RX bytes:0 (0.0 B) TX bytes:2598 (2.5 KiB)
 eth0 Link encap:Ethernet HWaddr B8:D8:12:67:0F:2E
 TX packets:148 errors:0 dropped:0 overruns:0 carrier:0
 RX bytes:0 (0.0 B) TX bytes:45745 (44.6 KiB)
 Interrupt:5
 ra0 Link encap:Ethernet HWaddr B8:D8:12:67:0F:2D
 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
 Interrupt:6
